Sponsored by: Auxito
5.4 stops without warning
Old Oct 19, 2009 | 08:56 PM
rsstiegler's Avatar
rsstiegler
triton 5.4 engine went from running fine to shutting off. I took off the throttle boddy duct and put some fuel in and engine started. I think fuel problem for sure. I can here the pump run for a few seconds at first which I think is normal. anybody have any suggestions?
Old Oct 19, 2009 | 09:25 PM
Ultramagdan's Avatar
Ultramagdan
Welcome!
You have no codes? Have you checked the fuel filter? After that it may be time for a fuel pressure test.
Old Oct 20, 2009 | 07:37 AM
rsstiegler's Avatar
rsstiegler
No check engine light. Fuel filter chanced about 10,000 miles ago. I took the duct off of the throttle body and put some gas in the manifold and the truck started on the fuel I put in. So it is a fuel problem. I guess I could change the fuel filter just in case. I wonder what other than the fuel pump it could be. Is there something that would stop the signal from operating the injectors.
Old Oct 20, 2009 | 01:54 PM
redwood's Avatar
redwood
How does it run once you get it going?
Old Oct 21, 2009 | 07:23 AM
rsstiegler's Avatar
rsstiegler
Turns out the fuel pump is the problem. Not cheep but how much more than 200,000 miles can you expect the pump to run I guess. This has been a great car and is still in good shape.
