Alittle lost here
Old 07-22-2014, 01:44 PM
xrsfsho's Avatar
xrsfsho
xrsfsho is offline
Alittle lost here
Hello, i just picked a f150 with some side damage a couple months ago, and now
Im sitting down and trying to compile a price lift of things that need to be done. Obviously in the picture i have there is some damage on the side of the vehicle. I have notices that you can cut and re-weld a new patch in, But i have no idea where to find them and who would have the best one. If anyone would have an idea i would appreciate it.
Old 08-01-2014, 10:43 AM
xrsfsho's Avatar
xrsfsho
xrsfsho is offline
any body have any suggestions other then going to the scrap yard and having to take the bed off a truck cutting it and then re doing it on my truck?
Old 08-01-2014, 03:00 PM
JWA's Avatar
JWA
JWA is online now
Received 1,394 Likes on 1,103 Posts
The only thing quickly coming to my mind would it be better in the long run finding a complete good condition cab instead?
Having once owned a body shop I'm sure grafting a replacement corner on that cab will end up being more trouble than its worth, not lasting a long time without rust starting to form.
Right away that might not seem like a great idea but it really would be the best approach if you're planning on keeping this as a working truck.
Old 08-05-2014, 09:58 PM
CharlieLed's Avatar
CharlieLed
CharlieLed is offline
LMC should have a repair panel for your truck. If you find one then I would recommend using panel adhesive to install it rather than welding. Unless you are an accomplished welder/bodyman I think that welding that panel would be a hige challenge to get straight.
Old 02-16-2015, 10:37 AM
holdbeerwatchthis's Avatar
holdbeerwatchthis
holdbeerwatchthis is offline
you need to weld it, if only spot welds. It needs to be welded, the glue works wonders and is great, but iv always did spot welds where it had them at factory and never had a problem. go to the salvage buy some cheap piece of metal close to the thickness of the truck, do some experiments on the settings, you want to weld it not burn though or have high build. its not rocket science i can teach a monkey to do it.
sum_weirdo
07-27-2016 07:49 PM
johnvosh
Paint & Bodywork
03-29-2012 08:10 AM
428fourby
24
01-08-2012 12:48 AM
xc4jokestomper
09-15-2011 05:31 PM
J2Davis
02-18-2009 10:26 PM
Quick Reply: Alittle lost here
