I have a truck that is new to me its a 1987 f-250 4x4 with a 460 and i just noticed that when i have the igniton switch on without cranking it my ignition coil is hot I'm just woundering if this is normal or if there is thing wrong
Something's not quite right --- either high internal resistance (check with an ohmeter -- anything higher than 1.0 ohms (primary) and 11,500 ohms (secondary) would be a problem) or something nearby (e.g. distribution, associated electronics) is shorting/failing thus causing it to pull high battery current.....
It may be normal with your type of ignition. Just unplug the Ignition Control Module (ICM) while you have the oil switch jumped and working with the fuel system.
