New turbo installed
New turbo installed
Spent last Saturday installing a new turbo on my truck. The original turbo started making a high pitched ringing noise and boost was not consistent. I had no boost at light to part throttle with lots of black smoke from the exhaust, then suddenly it would over boost.
https://www.ford-trucks.com/forums/1...h-whistle.html
I installed a new (not reman) stock Garrett turbo and the updated oil drain tube. I also picked up a Ford Turbo install kit.
While removing the intake hoses, I found out why the crankcase breather was leaking oil all over the place, someone installed the incorrect o-ring. This one is distorted and swollen. One of the tabs on the plastic connector was broken too.
One video I watched suggested cleaning the engine area once the turbo was removed, this prevents debris from falling into the oil return opening in the cover. I was surprised to find lots of dead bees. I know them at sweat bees, but I am sure there is a proper name for them. A few minutes with the shop vac had the area cleaned.
Everthing went smoothly considering I had never had this turbo off before. The only thing I struggled with was the exhaust up-pipe clamp. It was corroded and eventually broke. I was able to spot weld it and get it back on just I could drive the truck. I have a replacement clamp ready to go on this weekend.
With the new turbo installed, the ringing noise is gone and the boost is consistent, with no black smoke.
In the picture the new turbo is not sitting flat/in the same position as the old turbo, so it appears to be clocked differently. The new turbo is exactly the same as the original.
took me roughly 6-7 hrs, but I was taking my time and doing other projects at the same time. this also included 2 trips to the parts store, a lunch break and screwing around with the broken exhaust up-pipe clamp to get it to hold in place so I could drive the truck.
