High pitch whistle
High pitch whistle
getting a high pitch whistle noise only at idle. truck will make this noise on a hot restart, only at idle. No noise at cruise or under throttle.
I suspect the turbo is making the noise.....VGT?
here is a short video;
http://www.85merk.com/members/eric_s/IMG_0119.MOV
Got it now (at home on iPad). Hard to tell if it's whistling or ringing but definately a sound that shouldn't be there. If it's boosting well under load I'd pass on the cold side leak to start with(also it's making little to no boost at idle). Could be exhaust leak but it would be tiny and just the right shape to whistle.
I think I would pull the belt and crank it for a minute to eliminate a bunch of stuff at once. Alternator looks new could be a bearing in it-not uncommon. Maybe pull the air filter and tubing to look in the cold side of the turbo for the turbine wheel to be not touching the housing, free spinning, and end play on the shaft.
turbo seems to be boosting properly, at least there is no noticeable difference between now and the past 2 yrs I have had the truck.
I thought it was a an alternator noise too, installed a reman alternator and it made no difference. I had the belt off 2 weeks ago and everything on the front seems to be turning normally by hand, but I didn't start it with out the belt off.
I condensed the video so it should be easier to down load, if you were not able to before.
also, you need quicktime or windows media player installed on your computer for it to play correctly.
anybody else have any ideas? or experience with such a noise.
Listen for the high pitched ringing or whistle noise in the video.
I would use a long piece of heater hose. Put it up to your ear and use the other end to probe around all of the boots, cac tube, turbo, alt, pulleys and etc to see if you can pinpoint it. I've used this method for years and it's never let me down.
Oh and I definitely hear the ringing/high pitched whistle. A piece of hose should really amplify that noise well.
Dukhunt22
03-28-2007 12:06 PM
