1942-47 Parking Lights Measurments???!!!
Thanks
Thank you so much! I'm actually doing a very similar paint job to yours on my truck!!! I just need the diameter of the light itself and lens. I may not go stock since I did Halogen Head Lights.
Beautiful work on your truck! You skill set is great!
The light bezels are 3.75" outer diameter, 2.75" inner diameter. The inner diameter measurement is the visible ring edge. It has a 1/16" inch inner bend [lip] (at the lens edge) which lays on the glass making the true inner diameter 2 5/8"
If you need a pict, I can take one for you.
PS. Lens is 2 7/8" total (mostly - manufacturing leaves a little bit to be desired) , 2 3/8" raised area.
Thanks
Option #1 PIAA
These lights are 3.5" Diameter but I think I can make them work!
Frenching them like this
Thanks
Thanks Chris. If you're converting to 12v and its not a stock restoration. Why not run modern halogen, LED, or H4 bulbs. Its brighter, better visibility at night, and looks alot more attractive then those old sealed beam head lamps. The park light lens have always reminded me of those glass insulators from rail road tracks lol
gingerbreadmaniac
12-13-2005 01:55 PM
gingerbreadmaniac
08-22-2005 04:55 AM
