Head information needed
The info posted by Oldman indicates that the heads I have are functionally the same as the F1ZE. The plan is to do a simple gasket match and grind out the thermactor bumps and bolt em on inplace of the D6s I have now and stab in a new cam.
Conanski, what would be the approximate CR be with my current flat tops.
on
Ok so existing compression ratio with D6 heads wouldn't be quite a low as it would be with the stock pistons but the end result with the GT40 heads will be about the same or around 9.2:1.
P.S. Don't gasket match the heads leave that to the Chevy guys that don't know any better, if you do anything check the head/intake ports for misalignment in their as-assembled position and grind where necessary to make them match better. It's pretty much a certainty that the port openings in the heads will be larger than the exits in the intake and you will have to open up and align these and not touch the heads at all.
LOL sorry to but into someone else's thread but i'm in need of a little head advice and you guys seem to know what your talking about, i was curious on what models and years ford produced the gt-40 head and could they be used on a carb'd 351w and if not what would work well with an Edelbrock "street master" manifold with a 780 Holley??????????? thanks
You're not going to see a one point change in the comp ratio from a 4 cc reduction in the chamber size on a 351. More like 3 tenths difference.
lol, agreed. port-matching is the proper technique and yes, the intake ports on the head are almost always larger in diameter than the ports on the intake, unless it's a high performance intake designed for a head with larger than stock intake runners, in which case if there the port on the intake was larger than the port on the head and it presented a significant restriction to airflow then we would port match usually using the correct intake gasket, cheers
http://www.summitracing.com/parts/wrl-053040/overview
http://www.competitionproducts.com/S.../#.U8kFaDbD-Uk (ask if can get for SBF)
TheNomad
07-09-2008 08:27 PM
jimmyk57
04-27-2003 06:47 AM
