Swapping interior lights to LEDs
Hey guys I'm going to switch the dome lights and the door lights to LEDs and I just want to make sure I'm getting the correct bulbs.
If anyone confirm that these are the correct size bulbs for a 97 F250HD XLT?
Dome light
Door Lights
Dome light
Amazon.com: Cutequeen White 42mm(1.72") 8-SMD 12V Festoon Dome Light LED Bulbs 211-2 212-2 569 578 - White (pack of 4): Automotive
Door Lights
The dome might be right, my 350 uses that style but my 150 doesn't.
Got dash,door,dome,glove box,tag, under hood leds for my 150 here: LED Replacement Bulbs for Cars | 12v | Super Bright LEDs | Super Bright LEDs
Then these should work?
578 LED Bulb - 9 LED Festoon | Festoon Base LED Bulbs | LED Car Bulbs | Super Bright LEDs | Super Bright LEDs
When I ordered I chose the warm white color option. The data sheet showed 3500K (color temperature), and when I installed them in my map lights I wasn't disappointed. The light they give off is real close to an incan (regular) bulb. The center dome light takes a 578 festoon also, at least on my truck.
These are the ones I bought From Amazon
Jtech 4x 42mm(1.72") 16-SMD DC 12V Super Bright White LED Bulb 211, 212, 211-2, 212-2, 214-2, 560, 569, 578, 6413, 6429 etc.
One of these days when it cools off i'm going to remove the dome lights and jump the map lights to come on with the dome lights like my ranger
Thanks CrewCabber, those are actually the exact same one's I was looking at this morning.
I'm just hoping these dome lights fit okay, since they are a little wider.
But I checked out the light housing for mine and I think there is room. And it also looks like the map lights are the same bulbs
I went ahead and ordered both of these, we'll see how they turn out.
Amazon.com: Jtech 4x 42mm(1.72") 16-SMD DC 12V Super Bright White LED Bulb 211, 212, 211-2, 212-2, 214-2, 560, 569, 578, 6413, 6429 etc.: Automotive
I got the LED's yesterday and just got them installed
I also decided to change the temp controls and the tag lights since I had extra bulbs.
I'll get more pics when it gets dark tonight.
EDIT: And also now that I've changed all of these I want to change the bulbs in the third brake light, and reverse lights to LED, does anyone know what size bulbs I would need for those?
