Ring Gear Size
Old 06-25-2014, 10:57 AM
bluecobra's Avatar
bluecobra
bluecobra is offline
Ring Gear Size
I have an 2001 F-150-5.4-4wd-H-9 diff.
Looking on RA to buy rear axle bearings. How can I tell if the ring gear is 8.8 or 9.75. I have seen posts that said if the diff cover has 10 nuts its 8.8 but if it has 12 its the 9.97. I know there's a tag on the diff with codes, I'm hoping there's an easier way to tell than having to climb under the truck.
Any and all help is appreciated.
Old 06-25-2014, 04:12 PM
Bluegrass 7's Avatar
Bluegrass 7
Bluegrass 7 is offline
Get under and look.
Suppose your told wrong?
The truck had several options for size depending on model and build.
H9 is the ratio and open or limited slip ID.
Good luck.
Old 06-25-2014, 06:00 PM
bluecobra's Avatar
bluecobra
Thanks Bluegrass,
I did get under and its a 9.75 RG.
Old 06-25-2014, 08:55 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
this is the smaller 8.8 inch - note cover circle
Old 06-25-2014, 08:56 PM
steve(ill)'s Avatar
steve(ill)
9.75 is more egg shaped
Old 06-29-2014, 10:21 PM
STOFFERJ's Avatar
STOFFERJ
STOFFERJ is offline
all 5.4 equipped F-150's had 9.75's from the factory
Old 07-01-2014, 03:50 PM
bluecobra's Avatar
bluecobra
Got bearings & seal for the 9.75. Pulled the old ones and discovered the the 9.75
bearings were too big. It took the 8.8 bearings instead. Go figure!
Golflug
1997 - 2003 F150
02-16-2011 11:45 AM
briansortland
1997 - 2003 F150
05-03-2010 07:40 AM
DungeonCustoms
1997 - 2003 F150
07-12-2006 03:46 PM
shug5484
08-22-2005 06:11 PM
caswensk
1997 - 2003 F150
04-30-2005 06:36 PM
Quick Reply: Ring Gear Size
