I have a similar thread going on in the superduty section but I figured I'd ask here as well. I'm looking at a 2003 F250 with a 5.4 really nice truck. I'm just concerned with the blown spark plug issue with this engine. The truck has 135k on it.
the ejecting spark plugs was a issue with too little torque on the spark plugs. I think earlier models were down around 14 ft/lb on the spark plugs. ? This was remedied with increasing the spark plug torque to 28ft/lbs. Those who did this higher spark plug torque virtually eliminated the issue.
In the mean time Ford did increase the amount of material in the heads for the 03' units. Or at least this was the case for the f150's, presume that revamped head design followed to the f250's too.
IF your considered unit has not had the spark plugs changed yet....then it very likely due anyway & you can make sure they get the 28ft/lbs treatment
Thanks for the response. The torque does seem to be the consensus to solve the problem. I don't believe the plugs have been changed but he did mention a case of blown plug.
IF it had in deed puked a plug...then getting all the details as to how it was repaired is critical.
IF it was repaired with a Time Sert...then odds are good it there to stay.
IF it was repaired with a Heili-coil...I would be very suspicious that it will need to be redone...sooner the better
Hes asking 8,500 I know I can get him down from that a ways. The trucks in really good shape. Small dent in bumper is about all that's wrong with it. Regular cab long bed xlt
