Spark Plug Blowout
Old Sep 1, 2007 | 12:15 PM
zarillus's Avatar
zarillus
Exclamation Spark Plug Blowout
I'm about to change the spark plugs on my 2001 Expy 5.4 L and I was curious what you guys think about using red loctite on the spark plug threads, so i don't have to worry them blowing out.I don't have the money for helicoils or any kind of inserts.Also is there a certain type of plug that is less likely to blow out.
Old Sep 1, 2007 | 12:18 PM
Beechkid's Avatar
Beechkid
Oh my Noooooo!!!!!!!!!!!!!!!! Use anti-seize compound and torque to OEM specs...you will be fine.
Old Sep 1, 2007 | 03:13 PM
MisterCMK's Avatar
MisterCMK
do NOT use loctite. Like Beechkid said, some anti-sieze on the plugs and a torque wrench will go a long way.
Old Sep 1, 2007 | 03:15 PM
thavngr98's Avatar
thavngr98
good luck did mine today. I used anti-seize as well
