Check engine worse case?
It's not the transmission.
Brittany
others have chimed in on worst case....
best case is based on my experience with my light coming on and staying on....2 tanks of gas with lucas fuel system deep clean resolved it.
I'm sure if I would have taken it to ford and had them replace all the sensors in the fuel and exhaust system that would have worked also.
I encourage you to work with your dealer, Fastfwd, they're in the best position to diagnose this concern. Do you have an appointment for this upcoming Wednesday? Fill me in with some details via private message including full name, VIN, updated mileage, best daytime contact number, and dealership information. I'll look into this further.
Brittany
Brittany
Transmission faults have never set the CEL on Ford trucks as far back as I can remember. Early Super Duties would flash the "O/D Off" light if there was a transmission fault. Later models would flash the "Tow/Haul Mode" light. The OP's 2011 would illuminate a wrench symbol for a transmission fault.
Well my bad on that. Thanks Tom for clarifying. I have seen scores of transmission codes that did set the CEL in the past and working as a Smog Tech in California we have even replaced a transmission on a VW to allow it to pass the smog inspection but I didn't realize Ford trucks didn't set them.
others have chimed in on worst case.... best case is based on my experience with my light coming on and staying on....2 tanks of gas with lucas fuel system deep clean resolved it. I'm sure if I would have taken it to ford and had them replace all the sensors in the fuel and exhaust system that would have worked also.
slddnmatt
05-24-2015 08:25 AM
rustee90-150
11-11-2007 05:03 PM
