The never ending ABS light thread
Literally non stop. I have tries to sort this out and have not had much success.
What I have done.
Replaced VSS
Cleaned all dash foil connections
Cleaned all pin connections at the module and controller
I have tried grounding the blackorange wire to read codes, nothing happened. I will read up on this
So this is where I am at. The abs light is always on not brightly but on none the less.
What I haven't done
Bled the abs module. I am not sure how to do this solo.
What I have done.
Replaced VSS
What I haven't done
Just the ABS light. It comes on and stays on. I am guessing its something with the harness. I need to find a wiring diagram for it no that the 96 bronco shop manual link is dead.
I don't remember which fuse it was. It was probably #15, but #13 says ABS memory, but if the hazards/turn lights work it won't be #13. I was thinking it was a low amperage fuse, but #15 calls for a 20 amp, and #13 calls for a 15 amp. It had to have been one or the other, as these 2 are the only ones that mention the ASB.
The following users liked this post:
95_4x4_jay
04-07-2005 12:28 PM
