Crank, crank, no start..let off the key and it STARTS!
Silliest thing I've seen in a while.
Usually starts in 1 second crank,but noooooo.
let off the key and it starts, everytime within a second or 2.
Starter spins fast, so not like running dead batter amperage
and you can crank it for a full minute and it will Not start
Get it spinning and let go of the key on the upstroke and
and it will fire every time, instantly.
I love these trucks.
Theftproof, for sure.
Your issue sounds very similar to the one in this thread: https://www.ford-trucks.com/forums/1...asing-key.html
Danr1 explains the most probable cause and how to test.
Received 3,113 Likes
on
on
Back in the day, there used to be a bypass wire to the coil so that it was getting a full 12V when cranking, versus about 9V when running. If the bypass circuit was broken, then you would get these symptoms. In the modern world I am not sure if that still applies (although the attached thread indicates that it does) so I would try running a wire directly from the battery + to the coil + and see if it starts normally in that setup.
Alexander Carlson
83
07-25-2022 01:13 PM
jh19686
Escape & Escape Hybrid
01-23-2011 07:52 PM
670johndeere
04-16-2007 07:42 PM
