Diesel in the valley
Old 06-14-2014, 09:14 PM
tractoman's Avatar
tractoman
tractoman is offline
I found a little puddle in the valley today. Visible from the passengers side outboard of where the FP connects to the damper. Sopped it up with a paper towel and ran it awhile trying to find the source. It is a Cali truck. The lower section of the fuel damper was a little wet but nothing dripping I could see with a mirror when it was running. Could it be just a loose banjo bolt at the rear? I don't see any moisture near the fuel bowl or fuel lines at the heads. Around the FP also looks dry. How the heck do you get a tool on the banjo bolt anyway. I do not want to remove the turbo.
Old 06-14-2014, 10:59 PM
fordman67's Avatar
fordman67
fordman67 is offline
Efuel wil fix it....im in love with mine.every one of these trucks needs it done!
Old 06-15-2014, 05:34 PM
IDMooseMan's Avatar
IDMooseMan
IDMooseMan is offline
You might need to modify a box-end wrench to tighten that banjo bolt. Not sure what the angle you need is, but heating up the wrench and bending it might work. I haven't replaced my fuel pump yet, (I need to), so I don't know what I'll need to make it easy.
Lil Red Sled
16
11-19-2011 08:38 PM
scootermcgavin
02-03-2011 02:56 PM
bass-n-fire
12-05-2009 10:56 AM
Mike8623
24
02-01-2009 11:20 AM
SMS888
01-12-2007 05:53 PM
Quick Reply: Diesel in the valley
