fuel leak
Old Nov 16, 2011 | 01:40 PM
Lil Red Sled's Avatar
Lil Red Sled
fuel leak
Hey guys I just picked up a 95 powerstroke and I started smelling diesel. After looking around there is a puddle of diesel on the back of the valley pan. Any idea of where it could be leaking? I was thinkin the back of the fuel pump? Thanks for the help
Old Nov 16, 2011 | 02:15 PM
DIYMechanic's Avatar
DIYMechanic
Fuel pump could be shot, Banjo Bolt (on the back of the fuel pump) could be loose, hoses could be cracked and leaking, or it could be that the fuel bowl needs new o-rings.
Try tightening the banjo bolt first (you'll need a 1 1/4" combination wrench).
Then I would look at the fuel pump if that doesn't do it. There is a weep hole in the bottom of the pump that seeps fuel when the pump is about worn out. You have to stand on your head with a mirror to see it though.
Old Nov 16, 2011 | 03:32 PM
Lil Red Sled
Ok il check it. I wiped my finger on the bottom of that banjo bolt and it was soaked with diesel
Old Nov 16, 2011 | 07:27 PM
DIYMechanic
Sounds like an easy fix then. Hopefully that is all it is!
Old Nov 16, 2011 | 07:41 PM
Lil Red Sled
Hope so. Il get more time tomorrow. Il probably replace the hoses while im there any ways
Old Nov 16, 2011 | 07:49 PM
DIYMechanic
Yeah, I just replaced my hoses with some stock hose I got from our local NAPA. Make sure it is SAE 30R9 rated hose. That is a higher pressure rated, diesel safe hose. They may call it "Fuel injection" hose. I also picked up a couple packs of fuel injection style hose clamps and used those too. They don't cut the hose like a typical worm style hose clamp does. All told, I think I had less than $20 in the hoses and clamps and had hose left over when I was done. I got a foot of each size (3/8" and 5/16") and was able to replace everything including the fuel drain hose and still have some left over for next time.
Old Nov 16, 2011 | 08:26 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Lightbulb
My first think is the fuel pump and the fuel is going back to the banjo bolt, but who knows, start with the banjo bolt. The weep hole its in the passenger side of the fuel pump. other sources of leaks are the fuel restriction sensor in the drivers side of the fuel bowl and the fuel bowl itself (o-rings or corrosion in the bottom).
Good luck.
Old Nov 17, 2011 | 11:39 PM
fludoc's Avatar
fludoc
I have the same issue but I don't know where this bowl is you guys are talking about. My 90 had a threaded bowl under the filter but my 95 just has the screw in filter with the threaded cap. Where is the bowl on the 95?
Old Nov 18, 2011 | 06:31 AM
DIYMechanic
The "fuel bowl" people refer to is the fuel filter housing between the HPOP and the Turbo.
Old Nov 18, 2011 | 07:32 AM
noshow's Avatar
noshow
grrrrr......I just had this problem, make sure your cap is good and tight!!!!! dont ask me how I know
Old Nov 18, 2011 | 09:14 AM
fludoc's Avatar
fludoc
Ohhhh, ok. So my 95 doesn't have that water separator bowl or whatever it was, under the filter like the old one did?
Old Nov 19, 2011 | 04:33 PM
Lil Red Sled
Looks like the weep hole on the bottom of the pump is leaking. So il replace the pump and some hoses
Old Nov 19, 2011 | 05:36 PM
fordpride's Avatar
fordpride
might want to rebuild the fuel bow while its out. you can get everything you need from dieselorings.com
Old Nov 19, 2011 | 05:37 PM
fordpride's Avatar
fordpride
Hope this helps you out
Old Nov 19, 2011 | 06:13 PM
Lil Red Sled
How do I bleed the air out of the system before I fire it up
