DTC codes P006A & P132B
P006 - MAF sensor code - part of Inferred EBP strategy.
P132B is a code related to the calibration from the recall 06E17 (part of the Inferred EBP strategy). It means that there is a problem with the VGT system. P132B is a fault code that is set if the required boost levels are not achieved during a learn cycle or at specific speed fuel demand points. This code indicates that there are issues with the turbocharger, MAF sensor, MAP sensor/hose, IAT2 sensor, intake leaks, or exhaust leaks, etc. Frequently it is a sticking turbo issue. This code can also throw a P0401 EGR code. (see video below at 1:53)
The 06E17 flash can cause trucks to bog and hiccup randomly. It can cause the EGR valve to cycle randomly to cause these symptoms. Cleaning the carbon off of, or replacing IAT #2 is a potential fix for this fiasco.
TSB-09-15-06 also applies
<TABLE style="WIDTH: 685pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=914 x:str><COLGROUP><COL style="WIDTH: 685pt; mso-width-source: userset; mso-width-alt: 32483" width=914><TBODY><TR style="HEIGHT: 13.2pt" height=18><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; WIDTH: 685pt; HEIGHT: 13.2pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=18 width=914 align=left>TSB-09-15-6</TD></TR></TBODY></TABLE>
and:
http://www.flatratetech.com/downloads/diesel_8.pdf
and:
