coolant and temp 96 psd
Old 05-21-2014, 09:02 PM
63ferd's Avatar
63ferd
63ferd is offline
I have a 96 psd and the temp never gets over N in normal. Also changed coolant when I replaced the thermostat And now the coolant changed from purple pre charge to a gray color? Any ideas why this happend??
Old 05-21-2014, 10:04 PM
farmert's Avatar
farmert
farmert is offline
The first thing that comes to mind on the grey colored coolant, is oil mixing in the coolant. Can you see any oil residue in the coolant resivor? The oil cooler might have crapped out on you, mixing oil into the coolant.
Old 05-21-2014, 10:06 PM
63ferd's Avatar
63ferd
63ferd is offline
Its just gray! Would my oil be gray to????
Old 05-21-2014, 10:23 PM
farmert's Avatar
farmert
farmert is offline
It could be, but the oil runs at more pressure than the coolant, so it will push the oil into the coolant. After the truck has set for 10-12 hrs.,you could unscrew the drain plug untill it is about ready fo fall out. If you have water in the oil, it will run out around the threads.
Old 05-21-2014, 10:26 PM
63ferd's Avatar
63ferd
63ferd is offline
Alright. How much is a new oil cooler?
Old 05-21-2014, 11:25 PM
farmert's Avatar
farmert
farmert is offline
Oil Cooler 94.5-03 - Riffraff Diesel Performance
This is for the oil cooler, but it may just be to o rings that seal the end caps.
Oil Cooler Seal Kit - Riffraff Diesel Performance
Old 05-22-2014, 01:03 AM
63ferd's Avatar
63ferd
63ferd is offline
Alright thanks guys!!
Jesser02EX
12-29-2015 07:22 PM
DeeJayWoody
07-19-2014 08:12 PM
RAMPAGE_F350
23
08-30-2008 08:29 AM
Flobber
08-07-2008 12:19 AM
Quick Reply: coolant and temp 96 psd
