I need to identify what this gasket or seal is called?
There should not be water there.
Do you have water in the oil?
Can you get a cooling system pressure tester and pressurize the system without the engine running? That's the best way to check for leaks. Spinning engine parts and fans blow it all over, so trying to find it on a running motor is difficult.
If it is in fact coming out where you circled, time to pull the front cover see what you find.
Other sources above that would be hoses, the T-stat housing and water pump.
Bigred1971
03-23-2016 04:11 PM
copen93
11-25-2014 09:08 PM
