Part identification help
Old Mar 21, 2016 | 07:49 PM
Bigred1971's Avatar
Bigred1971
What is this and where could I find one?
Old Mar 21, 2016 | 08:08 PM
HIO Silver's Avatar
HIO Silver
Salvage yard or places like Mac's or National Parts Depot.
Where thus far have you looked for a flywheel/flexplate inspection cover? And what transmission?
Looks like the same one on my NP435.
Old Mar 21, 2016 | 08:15 PM
Bigred1971's Avatar
Bigred1971
I haven't really as I am currently replacing the oil pan gasket on my truck and I noticed that one of the po's had covered a hole in the bottom of it with gasket maker and when I cut it off oil came out
Old Mar 21, 2016 | 08:58 PM
GLR's Avatar
GLR
The hole is OK. Probably the rear main seal was leaking. The PO might have thought he/she could stop the leak by plugging the hole. You might want to replace the rear main seal while the pan is off. Dropping that cover will give you a better idea where the leak id coming from.
Old Mar 22, 2016 | 06:30 AM
GaryKip's Avatar
GaryKip
Jerry rigging at it's finest.
Old Mar 22, 2016 | 10:55 AM
Bigred1971's Avatar
Bigred1971
Can I replace the rear main seal with just the pan off or do I have to pull the transmission to do it?
Old Mar 22, 2016 | 12:20 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
If an FE engine, the inspection cover is the same for all 3 & 4 speed M/T's: 1965/76 F100/350; 1963/71 Passenger Cars.
C3AZ-6366-A .. Inspection Cover / Obsolete
No Ford dealer or obsolete parts vendor has any.
Old Mar 22, 2016 | 05:08 PM
Bigred1971's Avatar
Bigred1971
Do I have to pull the Transmission to replace the rear main seal?
Old Mar 22, 2016 | 06:00 PM
sandman2102's Avatar
sandman2102
No, but replacement is a little involved....Google rear seal replacement and you may find the method that works for you.
Old Mar 22, 2016 | 06:13 PM
CougarJohn's Avatar
CougarJohn
Tape over the weep hole!
Man, that's one for Toothless Jake.
Old Mar 23, 2016 | 12:26 AM
GaryKip's Avatar
GaryKip
Yea, I bet the oil and water did a number on the clutch components.
Old Mar 23, 2016 | 01:43 PM
CougarJohn's Avatar
CougarJohn
I talked to Toothless Jake about the tape over the weep hole on the bottom of the inspection plate. Jake shook his head and said he would never half-**** it that way. Jake said he would do it right with a self-tapping screw and thread sealer.
Old Mar 23, 2016 | 04:11 PM
ultraranger's Avatar
ultraranger
He said he was fixin' to borrow a welder from Bubba and then he was going to remove the screw and then zip that hole up right.
F-250 restorer
17
Oct 19, 2010 07:40 PM
93f1504x4sclb
Sep 29, 2010 07:04 PM
Sgt Neutron
Aug 10, 2010 09:54 PM
bigblock86
Dec 31, 2009 04:25 AM
Cor
Mar 3, 2006 12:16 PM
