Leak behind harmonic balancer
Old Nov 24, 2014 | 08:23 PM
copen93's Avatar
copen93
So we got a timing cover from the junk yard, cleaned it up real good, put a new seal, new gasket, new harmonic balancer, and now after a few days I run the engine around for like 1 hour going to places and I have a few drops coming from behind the harmonic balancer? Any ideas?
Old Nov 24, 2014 | 08:32 PM
JWC 3's Avatar
JWC 3
What engine do you have ? Is the seal leaking ? or the pan gasket ....
Old Nov 24, 2014 | 08:34 PM
copen93's Avatar
copen93
300 i6 4.9 1993 F150, I was looking at it and was wondering if it might be from the pan gasket, but the harmonic balancer is covered in oil from the top to bottom, so if it was the pan, would it cover the balancer?
Old Nov 24, 2014 | 08:37 PM
rugermack's Avatar
rugermack
Does your balance have a "groove" in it where the seal rides on it ?
Old Nov 24, 2014 | 08:43 PM
JWC 3's Avatar
JWC 3
Did you lube the seal before installing the balancer ? The crank bolt may require thread sealer to prevent leaks ... Not sure on that .
Old Nov 24, 2014 | 08:45 PM
JWC 3's Avatar
JWC 3
Also check your PCV system for proper operation , that WILL cause leaks to form if not proper .
Old Nov 24, 2014 | 08:52 PM
copen93's Avatar
copen93
I'm sure they did, my neighbors did it, they are both certified mechanics. I really don't want them to take this bugger apart again.
Old Nov 24, 2014 | 09:06 PM
copen93's Avatar
copen93
Here is a picture from the bottom http://imgur.com/bpbhkuO this is after wiping it down a little bit.
Old Nov 24, 2014 | 09:27 PM
JWC 3's Avatar
JWC 3
Time for a second opinion . Take it to a shop or service station . Have them put it on a rack and watch it while it is running . They may need to put dye in the oil . The leak should show . The front of that pan gasket does not look proper from what I see .
Old Nov 25, 2014 | 02:03 AM
tbugher62's Avatar
tbugher62
Probably didn't get the portion of the pan gasket set right when they put the timing chain cover back on.
Old Nov 25, 2014 | 12:53 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Ditto on that.
Old Nov 25, 2014 | 03:53 PM
copen93's Avatar
copen93
Where should I go from here? Just keep an eye on the oil level? I really don't have the money to pull the engine out of it to get to the gasket.
Old Nov 25, 2014 | 09:08 PM
tbugher62's Avatar
tbugher62
You dont have to pull the engine out too replace the gasket,get a timing cover gasket set,it has all the gasket's you need to fix the leak for about $20.00,you will have to pull the water pump,timing cover,e.t.c.
oem78
Sep 29, 2010 01:38 AM
Canadianice
Bronco II
Jun 28, 2007 05:21 PM
waldreps
Apr 4, 2005 10:39 AM
GammaDriver
Dec 8, 2001 04:12 PM
turbogus
Oct 30, 2001 02:50 PM
