I have a 2000 SCrew KR F150. A couple of weeks ago I noticed the brake pedal was slowly going to the floor while at a red light. I pulled over and popped the hood checked the fluid reservoir. It was full, so obviously no wheel cylinder issues or fluid loss. Any suggestions? I haven't had a chance to tear into it yet.
I appreciate the help guys, I am new to the 150s. Just trying to learn all that I can before I go rip-snorting into it. With an ABS problem wouldn't the light be on?
Reason: Forgot to add something
More than likely (as the other guys said) it's an internal leak in the master cylinder. So far *knock on laminate covered particle board* I haven't had problems with either of mine.
......curious to see how he made out.....The abs module bypassing fluid has been an issue also..not a cheap fix there! I have been waiting to take the plunge and buy a new one$$$
Hmm, common problem, eh? Maybe that's why my 98 does that? So if it is the master cylinder, it would not brake well at all, even if you put hard pressure on the peddle, would it?
