I saw the pics and it looks like something I need too. You say the injectors like it. For the trouble, is it a good boost? Will it throw any kind of code or create an issue down the road?
larrygraham76
larrygraham76
Blue spring upgrade should throw no codes and make for much happier injectors.
larrygraham76
It takes 10 minutes to do. I wouldn't expect any real "boost" but it might keep you from killing a $1500+ set of injectors. It's a factory ford/international part intended to fix an issue with the part it supersedes. There's no chance of throwing any code. It's basically a "recall" but they call it an "update" so YOU get to pay for it rather than Ford. Your call...
Some of us are slower than others -- I think it took me a couple hours, but I was damn careful.
Never checked fuel pressure -- before or after, contrary to what some others do. The spring should raise the fuel pressure about 10 psi. I think, besides monitoring your truck's vitals (and fixing what needs fixing), it's one of the smartest and easiest preventative things to do...
i checked my fuel pressure this past sat read 70psi at idle and 60-61psi at wot. i think the facory installed this update kit a yr or so after i got the truck in 06 bc there was a fuel leak there...
I have a fuel pressure gauge and have exactly the same pressure range after the blue spring upgrade. Not many others see 70 so we're lucky.
