Hey guys, I have a 1993 f-250 that im pulling the engine out of (351W) and putting a 1997 powerstroke into it along with a new (to me) zf5 transmission. Thoughts, comments, or ideas to help would all be appreciated. Currently stuck on removing the E40D transmission off of the diesel, any help?
-Eric
Having a problem getting the top most bolts on the bell housing. Torque converter is already unbolted and axel has been pull out. I guess i forgot to mention this engine is still in the truck. A 1996 f-250. I currently have it mostly ready to come out. Just the tranny and the wiring harness.
In Oregon
-Eric
I have a 3-ish ft long extension just for those top bolts. Between that and possibly a universal (and maybe another extension or two) I run it over the tranny and loosen from the rear of the transmission.
Also not that those bolts should be the first to come out, not the last.
If they are the last, as you loosen them the tranny could put weight on them and make them a pain and possibly damage the threads.
Richard
EDT: note that this is general advise, I have not actually pulled the tranny in my truck but have pulled trannys in many other vehicles. be sure you use a tranny jack.
I take that back, i think i have the plate, i have the flywheel and the clutch plates. Is that what you're talking about?
there is a plate that goes between the engine and the transmission bell-housing. it is different between the manual transmission and the automatic.
Also, if the flywheel you have is an original dual mass, I would recommend replacing it with a single mass flywheel and clutch set... Dual mass flywheels have the tendancy to grenade.
Well part 1 of 3 is done. Got the diesel out with little to no difficulty and was even able to leave the turbo attached. On to step 2, remove the 351w from my 93.
