Headlight Buzzer Questions - Clarification
Newbie here...
I just got a nice 1994 Ford F-150 Sport XL Standard Cab Pickup 2-Door 4.9L 300Cu. In. l6...love it, so far.
I've read all the posts regarding headlight buzzers, etc...
Can someone tell me if my truck has the headlight buzzer option? I read that it might not have been an option on XLs. This would save me time in determining if mine's broken or absent.
Also, do these trucks have floor courtesy lights? Mine doesn't seem to, but it might be burned bulbs. Where are the sockets located under the dash so I can verify.
This place is awesome, btw!
Nec
Nec
88 F0RD XLT Custom
When you have your headlights on, not just the park lights on,
key out of the ignition,
go to open the door to exit the vehicle,
and it makes a buzzing sound,
you have a headlight buzzer,
same thing that happens when the key is in and the drivers door is open.
You can order them from LMC truck,
mine already had one installed, not sure if its factory or someone added it on. great thing to have though.
not sure really
it could be a number of things
just guessing.
check your fuse panel, it could have a headlight buzzer fuse??
if its not working,
it could be a broke ground wire in the door that's connected to the switch??
the horn buzzer switch is bad between the headlights and the headlight ****, it could be located anywhere between the headlights and headlight ****,
LMC tuck has these with directions if you could get more info on that it would give you a better general idea on where the switch would be located.
not really sure, but my 88 F0RD does have one, and it does work with the key out and headlights on.
really neat to have.
if yours doesn't have one, they are not expensive from LMC truck. page 146 in the online magazine. here is a link.
Truck Parts and Truck Accessories part number (36-3617) <-----LMC Truck 1980-1996 Ford Truck
$9.95
just guessing.
if its not working,
$9.95
Newbie here...
Nec
Nec
Update:
Hope this helps others.
So, my truck's warning buzzer module has 6 connectors - these operate the key-in buzzer, seat belt buzzer. The connector it plugs into has 7 connections - the 7th is for the headlight-on warning buzzer. It's the brown wire. Just use a tester to verify you have 12V to the 7th, key out, lights on. Mine did.
So, if you swap the 6 connector module with a 7 connector module, you'll have a headlight buzzer built in.
Of course, you could also get a decent aftermarket one for LMC, but I'm sorta partial get the all-in-one, ford module.
Thanks again for the input.
Nec
Nec
