Truck has a mind of it's own
1988/302/C6/4x4 Pulled it out of storage last week since the weather warmed up. Filled it with gas and been driving it to work every day with no problems. Friday morning, started it up, drove it to the bank, went in cashed my check, came back out started it up drove it to my grandma's house. Left there an hour later started it up drove it to work. Came out on break to go to the store, hit the key and it would sit there and crank but not fire. Sprayed carb clean in the intake, still couldn't get it to fire. Smelled like it was getting fuel anyways. Checked for spark getting spark. Nothing appeared to be wrong with the truck but I stayed out there till about midnight with no luck before I called it a night. Went back saturday morning, hit the key and she fired up. Drove to the gas station, shut it down, filled her up, started it and drove it home. Went to go to my buddy's house about an hour later, got in it, hit the key, and it would sit there and crank, but not fire. Same symptoms. What the hell?
It threw an EGR code, I've never replaced the EGR so I went ahead and put one on, didn't expect it to correct the problem but I did it anyway. Test drove the hell out of it yesterday, I would start it, drive it around, bring it home, park it, repeat. I did that intermittently all day, started it probably 10-15 times between noon and midnight. Put 25 miles on it doing so. Ran great, started every time. Come out this morning to take it to work, got in, hit the key, and she fired up. Sat there for about 30 seconds and she just died. Hit the key and she started again, but was running rough. Gave it throttle and blew black smoke out of the tailpipes...when I let off the gas she just died again. I decided screw it and drove Ol Reliable to work instead but what the **** man. I drove that truck all around yesterday and it ran great.
Used to have an issue where it wouldn't start cold, had to give it carb clean to get it to turn over. Put a new computer in it and solved it though. I have a spark checker, and it's saying that I have spark.
don't use carb cleaner in the TB, it will ruin the coating inside the TB.
have you confirmed timing is set at 10* btdc with spout connector removed? the black smoke would make me believe its getting to much fuel perhaps. you might also consider running some seafoam thru the intake and the fuel system
Had ICM (TFI) tested repeatedly until it was good and hot tested good every time.
llangbehn
18
03-01-2013 10:21 AM
1986stepsidef150
06-19-2012 05:41 PM
*2fords*
12-19-2010 05:23 PM
