51 239 flathead first oil change in 51 years
#33
#35
It's still 150 miles from home, but that's a LOT closer than Santa Cruz.
WOODIES AT THE BEACH
13th Annual Woodies at the Beach
Santa Barbara City College
Santa Barbara, CA
August 17, 2013
9:00 A.M. – 3:00 P.M.
#36
I hesitated even starting this thread because it was not a truck.
#38
Welcome to FTE, I see this is your first post. Please start a thread and tell us about your 52 and how the first start up go's.
#40
#42
Oil Change info
Hi,
Thought I would tag a question here as the closest I could come without posting a new one.
I have recently purchased a fully restored 1952 Mercury 1/2 ton. It was a labour of love by Mike Decoffe.
It has a 255 flathead V8 but most outer atributes are the same as the 239.
Question - I am doing an oil change, I have removed the oil filter and bottom plug, oil has drained except for what is in the filter cannister. Do I have to remove the line to get the oil out.
#43
I wouldn't remove that line for that purpose. Just too risky to mess something up or start a leak. Most guys just sacrifice a couple of rags and absorb the oil that way, or you can use one of these.
http://www.harborfreight.com/media/c...mage_12992.jpg
Edit: Some of the oil filter canisters have a small drain plug at the bottom. Make sure yours doesn't have one before you do it the hard way.
#44
The line drains the center tube in the filter housing. The only holes in the tube to let oil out are halfway up the tube, so unless your housing has a drain valve on the side (rare), you are stuck getting the last half of the canister's oil out. If you suck that oil out like Doc says, see if the bottom of the canister is full of sludge. If so, now would be the time to remove the canister and clean it out. Any sludge in there is likely to contain lead compounds that may be absorbed thru your skin, so be careful and wear gloves!
jac08f250
1999 to 2016 Super Duty
46
08-22-2009 09:16 PM
