Rear Differential Question
A while back i changed my rear differential from a 4:10 to a 3:55.
its been running great with no noise from the rear axle as far as i can tell.
today i had some issues on my u-joint, and while the rear axle was up on jackstands i noticed a problem with my differential:
while in gear and the brakes loose, i can not turn either wheel.. i should be able to turn one wheel in one direction and the other turns in the opposite?
with out of gear and blocking one wheel, i can not turn the axle... its like i have a locked differential.. any thoughts?
If I understand your situation correctly, this is normal. My assumptions from your statement:
1. Engine is off.
2. ZF is in gear.
3. Parking brake is released.
If this is the condition you're talking about, the rear wheels will not turn because they are locked in running position by the driveline. Place your ZF in neutral and try it again. The wheels should turn freely with the parking brake released and the transmission in neutral.
1. Engine is off.
2. ZF is in gear.
engine is off, zf is in neutral, i can turn the wheels, but both spin in the same direction.
if i put it in gear, brake off, i can not turn one wheel.. shouldn’t the other one turn in reverse?
i am not aware of a limited slip and i do not have a locker. It is a stock sterling 10.25 with 3:55 gears.
05F250DSL
02-27-2014 06:03 PM
