1992 F150 5.3l v8: idle too high?
on
5.3? You have a chevy motor in your Ford.. that's your problem.
On a more serious note idle speed is computer controlled so if you can eliminate a stuck throttle cable or throttle linkage(remove the intake tubes and examine everything closely), then while the engine is idling in park unplug the IAC and the TPS one at a time to see if it makes any difference and report back with the results.
on
enzer2406
02-18-2011 01:39 PM
IcemanV8
22
04-11-2008 06:34 PM
mjb1962
02-23-2001 11:29 PM
