67 F100 SB 352FE/C-O-Matic to a 302/C4 from a '68 F100 SB.....Any Issues?
Old 04-06-2014, 08:50 PM
67buckeyeF100's Avatar
67buckeyeF100
67buckeyeF100 is offline
Hello Fellas......I have searched the forum, but couldn't find this same topic.
I have a 67 F100 Short Bed with a 352 FE and Cruise-O-Matic tranny.
I have come across a 302/C4 combo that is currently installed in a 68 F100 SB for a reasonable price including labor and adult beverages....
Are there any unforeseen issues in swapping the 352 for the 302/C4?
I can think of 3 right now....Motor Mounts, Tranny Mount, and Drive Shaft
I can probably get the motor mounts off of LMC/etc.
I can probably move the tranny mount if I need to.
The current drive shaft I have I could get modified, or I may, depending on the length needed, use a drive shaft that I have pulled off of a 1976 F100 SB that I used to do a swap out to PS/PB 6 years ago.
What do you fellas think? Thanks in advance of your advice.
Old 04-06-2014, 09:05 PM
bmuhlbach's Avatar
bmuhlbach
bmuhlbach is offline
The frame stands I believe or different. You can use the 302 or ones up to 79 from a 351M,400.The crossmember will bolt no issues just move to other set of holes c4 are shorter. You will need a longer driveshaft.
Old 04-06-2014, 09:15 PM
67buckeyeF100
Many Thanks!
Longer Driveshaft.....I have 2. One installed. One on the garage floor with came from a 360/C6, which is shorter. It would be nice if I could use the current. I will have to measure.
As for the stands.......I will procure those, shouldn't be too bad to do so.
Old 04-06-2014, 10:38 PM
Gembone's Avatar
Gembone
Gembone is offline
Be sure to check for shifter position, length, and linkage differences. I am not hands on familiar with the 2 transmissions so there may or may not be a difference.
Old 07-09-2014, 08:09 PM
67buckeyeF100
.before and after....
BEFORE......
AFTER......
Old 07-09-2014, 08:13 PM
Azcannon's Avatar
Azcannon
Azcannon is offline
nice work, I really like 302's , have one in my 93 bronco . I also really like the 360 in my 71 f100 !!
Old 07-09-2014, 08:18 PM
67buckeyeF100
I have a few more modifications left. One, the shift linkage on the tranny needs extended so that I have the proper throw on the column. The other is for the gas pedal. I need to extend the pedal rod about 1" so the pedal is not so touchy....lol........and I have got increase the bend on the driver side exhaust pipe for more clearance of the tranny mount.
This cost me for all parts, about $2500. Biggest expense besides the motor was the new drive shaft ($325), new radiator ($250), and exhaust (2.5" pipes with a 1.5" off-set to clear the tranny mount going to cherry bomb glass-packs, exiting 4" past the cab....) . Biggest modification was the passenger side engine bracket that needed to be cut and welded to allow for the headers to fit.
Best thing is, I got to get rid of the 352 FE PIG and increased my hP by a factor of 3.5......g
Next modification is increasing the 9" rear ratio to something higher than 3.0.
I'll worry about the body, some day.
Old 07-09-2014, 08:20 PM
67buckeyeF100
Thanks! The whole process was easier than I thought it would be. It was easier than the front end swap (from a '76 to convert to PS & PB from manual drums and manual steering) I did 7 years ago.
Old 07-09-2014, 11:24 PM
bmuhlbach's Avatar
bmuhlbach
Looking good. You ever go to Laural Square on Saturdays for the car shows?
Old 08-23-2014, 06:59 PM
67buckeyeF100
No. Where is that?
Old 08-24-2014, 10:00 PM
bmuhlbach's Avatar
bmuhlbach
Its in Brunswick RT.42 and Laurel Rd.
ridealong34
07-25-2014 12:40 PM
f100help
08-03-2010 10:18 PM
JasonB
Georgia Chapter
06-10-2005 05:16 AM
mikenusaf
13
02-07-2005 08:24 PM
ranolan
10-12-2002 08:01 PM
Quick Reply: 67 F100 SB 352FE/C-O-Matic to a 302/C4 from a '68 F100 SB.....Any Issues?
