Max towing capacity
Max towing capacity
What is the safe max towing capacity for a 97 f350 crew cab 2wd dually, 7.3 diesel with auto trans? I will be pulling a 3 car wedge goose neck trailer with it to a car show in may. Not sure what the empty weight is but previous owner said its 20-22k loaded down with 3 vehicles. Its 52 ft long and a triple axle.
Also what are some good mods to do before making a long trip? My may trip will only be 4 hours or so but in july ill be making a 12-14 hour trip loaded down. Right now the truck has arp headstuds, 120hp injectors, and complete turbo back exhaust. I am buying the ts 6 position chip today and plan on having cold air intake and gauges soon. What else are must haves for my trips?
I think you will be all right with the weight you posted. Be sure the brakes on the trailer are up to snuff. Depending on the lay of the land, your exhaust temps may get on the high side, 1250 is the max sustained temps you want. If you don't have an aftermarket tranny cooler, I would recomend one. Heat is a killer of these trannys. I have heard one from a 6.0 equipt truck is good. Im' not an auto tranny fan, so some one with morr knowledge will chime in I'm sure.
Im from louisiana but i just got it a couple months ago out of georgia. It does have 24" rims. No clue on gears. Rearend is a 10 lug rear supposedly out of a box truck
By the way what is the stock turbo supposed to look like? Im not sure if mine is stock
Hey you might check out the Trailer Life Towing Capacity Guide for your model year, you will be able to find the info you are looking for:
Also, if you are going to be towing regularly, I would like to recommend the StableLoad suspension upgrade to you. It is an easy DIY and there are also models available for the lower overload that are quick disconnect so you can disengage them while they are installed on the truck. They help reduce body roll, sway and bouncing.
I think you would like them. PM me with pictures of your overloads and I can direct you to a dealer in your area.
- Torklift Jen
- Torklift Jen
__________________
Torklift International – Towing, Suspension, Tie Downs, Steps
Call me direct: 1-800-246-8132
Visit our Blog: http://www.torklift.com/blog
Stolher
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
06-06-2013 09:52 PM
Jermbob
21
04-07-2013 09:08 AM
