99.5-03 F-350 7.3 towing capacity
Old Mar 6, 2013 | 01:33 PM
Jermbob's Avatar
Jermbob
what's up guys I'm new to the membership but have read alot of the Forums here and have been impressed with the site so I figured I would go ahead and join ya'll...I'm looking to buy a 99.5-03 F350 7.3 CCLWB...I'll be looking to tow a travel trailer around 7000 lbs with a EZGO electric golf cart in the bed...Im wondering if the truck would be able to handle that much weight on the RGAWR or how much it would affect how much tongue weight I could have on the TT with the golf cart in the bed...would I need to go with a DRW or possibly a newer gasser or just leave the golf cart at home(I dont like walking while camping...defeats the purpose of vacation )...any and all advice is greatly appreciated on what would be the best route to go...Thanks and have a good one!!!
Old Mar 6, 2013 | 01:53 PM
twg1966's Avatar
twg1966
Trying to Gain Knowledge
You really probably won't even realize you are towing it once you begin driving. That isn't really that much weight at all. I was towing a 14,000 fifth wheel for many years in the hill country here in Texas. You will be fine with that setup. Just get you some get some gauges installed to monitor the transmission and exhaust gas temps.
Old Mar 6, 2013 | 02:12 PM
MTalley's Avatar
MTalley
How much does the golf cart weigh? I would suspect a dually (DRW) wouldn't have an issue. Not sure on a single rear wheel, though, as far as overloading the rear axle/tires.
Either would pull the combo, no problems there. I agree with your rear axle overload concern, though.
Old Mar 6, 2013 | 02:25 PM
1L243's Avatar
1L243
I am no expert but what I have learned is to know for sure you will need to check the sticker inside the drivers side door for the GVWR. It will probably be 8800 lbs. Weigh your truck loaded with passengers and fuel and subtract the difference is what cargo you can carry. You will also have to look at GCWR. The 1999 will probably be around 20,000 with a 7.3 diesel. So truck, golf cart (cargo) and trailer should not weigh over 20k.
A good guess is that your golf cart will weigh around 1000lbs. The TW on a 7000lbs trailer will be around 700 to 800 lbs...
Once all is connected and weighed you will know for sure... I don't think you will have a problem. Airbags will not increase your towing capacity but will make the truck ride better with the weight in the bed and towing a trailer.
Old Mar 6, 2013 | 03:24 PM
snakedoc's Avatar
snakedoc
it should be fine, i pull 16000+ at times and it dose not over load the axles. just load it right and you will not have a problem.
Old Mar 6, 2013 | 03:31 PM
Jermbob's Avatar
Jermbob
Golf cart should be around 1000 lbs...it's about 535lbs without batteries...I know I'll be good with everything except the rear axle/tires...it will add another 1000 lbs right on top the rear axle and that's where my main concern is.
Old Mar 6, 2013 | 03:49 PM
Brother Les's Avatar
Brother Les
IF you are not careful you will forget that you have a trailer back there...... It will be fine.
1999 Ford Super Duty F-Series can handle anything thrown its way | Ford Motor Company Newsroom
Old Mar 6, 2013 | 04:44 PM
MTalley's Avatar
MTalley
If it were me, I'd find a dually, but I'm obviously biased.
I think an SRW would be OK, if not a touch overloaded on the rear axle.
Old Mar 6, 2013 | 08:54 PM
crop harvester's Avatar
crop harvester
I haul 4500lb camper in the bed & pull 6000lb boat with no problems.
Old Mar 7, 2013 | 06:19 PM
73f250cummins's Avatar
73f250cummins
I haul 4500Ibs trailer with 4 snowmobiles and all out gear no problem. You dont even know its there besides the sway from the enclosed trailer.
Old Mar 7, 2013 | 07:13 PM
trekbasso's Avatar
trekbasso
Only other concern is of course tires. Get good E rated tires.
Old Mar 7, 2013 | 10:07 PM
Christof13T's Avatar
Christof13T
You know...
We should start touching on this more often with the noobs...
We take for granted the weight we can handle because were already used to running e's.
It hardly ever gets mentioned except for the few and far between rubber threads.
Old Mar 8, 2013 | 12:58 AM
dloomis's Avatar
dloomis
Where does one find a good trans temp guage and exhaust temp guage? What temps should they be running at? How easy are they to install. I am very mechanically declined, but would love to figure it out!
Old Mar 8, 2013 | 01:34 AM
1L243's Avatar
1L243
I got mine from Riffraff. Got with the package deal. Will get 3 gauge pillar, EGT, Boost and Trans Temp..... Of course then you will have to start thinking of a 6.0 trans cooler..
Old Mar 8, 2013 | 05:38 AM
Jermbob's Avatar
Jermbob
are the BF Goodrich all terrain TKO's a E rated tire? and how much would the trans cooler and gauge package run? I'll be looking to take very good care of the engine and tranny so anything that I need will be getting added on
