Y-Block Dampner Timing Marks
You're correct. My engine likes ~16° INITIAL ADVANCE, set with vacuum gauge but rechecked with light. But that will put my TOTAL ADVANCE way to high. That's where a light comes in, along with checking operation of vacuum and mechanical advance. No way to do that with just a Vacuum Gauge.
When using a gauge advance the ignition timing for max vacuum yes but then, ya hafta back it off at least 1 full inch of vacuum indicated on the dial. Make sure the vacuum advance hose is disconnected and plugged. Also ensure when you hook it back up that it is connected to ported vacuum, not manifold vacuum. Use a tach unless yer ears are calibrated good.
You probably won't be pulling 20 when you get everything set right, to include idle RPM, and idle mixture. Still, by doing this you'll be able to adjust the idle RPM to spec (500-550.w/ manual xmsn) and then, adjust the idle mixture screws for the maximum vacuum and smoothest idle. (Aka "super nice lope"!)
As you get the idle mixture settings dialed in you'll likely have to decrease the idle RPM setting. Holley's might like thing set a little higher - maybe 600 or so. Timing, as you have noticed affects idle RPM, and so does the mixture settings, they all affect each other so you'll have to go back and forth a bit. Make sure the throttle isn't sticking or binding, it has sat for a long time? Making these adjustments correctly will give good performance and best economy.
Make sure your float level is correct too, and check to see that the throttle plates are perfectly vertical when pedal floored (engine off) engine warmed up before you start all this, etc. - and you'll get to listen to that Y block music all the time!
Sent from my iPhone using IB AutoGroup
Not all dampners are marked the same. Some are on the pulley, some are on the balancer. Some are just a "v" groove, or a high spot. These dampeners are old and the rubber is most likely deteriorating.
I believe the good news is if they come loose, they dont go thru the radiator and down the highway at rocket launch speed.
They go towards the timing chain cover but stay on. At least thats what I have been told.
At the factory, a rubber gasket is placed between the inner damper and the outer pulley, then the three parts are pressed together forming a one piece assembly.
Over time, the gasket age cracks/shrinks, causing the outer pulley to begin to "walk away" from the inner damper.
If not noticed, the pulley can fly off the damper taking assorted belts and etc along with it...may end up in the radiator core. Not pleasant!
Whoever gave you this BS info...didn't have a single clue what they were talking about. The inner damper of the harmonic balancer is bolted to the crankshaft.
Thanks for clarfying that. My source was a vender who rebuilds Dampners, including Y blocks. I was trying to make it clear in my post that I was hesitant passing along that information. Looking at the Y block Dampner, I did not see anything that would keep it from going either way.
Can you give me some feedback, my 292 sat for 15 years and I have no idea if the damper is original or not. I do know the 292 is the not the original block but a rebuilt (.040" over) long block in the late 80's. Anyways the thing runs like a dream, but I can't get the idle down below 900 RPM. Timing is theoretically about 10 degrees. Vacuum at a solid 20". If I retard the timing I can slow the idle down but then I loose vacuum. My understanding is Vacuum is king, but maybe I'm wrong. One thing I noticed when I retard the timing is that my Y block sounds fantastic with a super nice lope. So I'm really stumped on my timing / idle. 1850 Holley is fresh rebuild.
Also check for vacuum leaks, i.e. intake, carb base, etc.
84respass
10-05-2010 10:09 PM
Orange '63
08-21-2008 11:40 AM
