A little help on leaking new water pumps
Its been a while since I logged in and said hey to you guys. I check in from time to time to see what's going on, but haven't spent much time here. I'm sure yall missed me
2004 F250 Crew. Had a busted radiator and replaced the water pump with the radiator. Used a new pump, and not rebuilt. Purchased from Advanced Auto. I chose one with a metallic impeller.
There is a small plug (a little smaller than a dime) just below the pulley. The plug leaked just a little, so I swapped the pump out with another new one. The second new water pump is leaking more than the first.
Anybody else had this experience? What manufacturer should I use?
Its been a while since I logged in and said hey to you guys. I check in from time to time to see what's going on, but haven't spent much time here. I'm sure yall missed me 2004 F250 Crew. Had a busted radiator and replaced the water pump with the radiator. Used a new pump, and not rebuilt. Purchased from Advanced Auto. I chose one with a metallic impeller. There is a small plug (a little smaller than a dime) just below the pulley. The plug leaked just a little, so I swapped the pump out with another new one. The second new water pump is leaking more than the first. Anybody else had this experience? What manufacturer should I use?
Dom
Sent from my iPhone using IB AutoGroup
say that you blew it out with high pressure.
I think your getting some bad parts also.
Sean
Greenmachine_76
05-26-2009 11:44 AM
70T351W
09-04-2006 05:48 PM
