Modular V10 (6.8l)
2012 V10 in Motorhome help with rpm
Old 03-29-2014, 12:41 PM
petrokiller's Avatar
petrokiller
petrokiller is offline
Sorry If this is in wrong room and OT.
Dad has 2012 Bay Star 29 ft Motorhome with V10.
He has been instructed as well as manual says, to keep rpm's under 3000.
It has 5speed with OD.
Does this sound right?? The power band is above 3000 rpm right?
He was told its bad for valves or something.
Any other rooms to post this in and I will.
Thanks in advance
__________________
Brad 2000 F250 XLT CC SB 4x4 7.3 PSD Bone stock GPR LED
Old 03-29-2014, 01:33 PM
Sancho's Avatar
Sancho
Sancho is offline
Once it's broken in,just put it in D and go. 4-5Krpm is OK
Old 03-29-2014, 02:01 PM
petrokiller
Dad was told the engine was a commercial V10. I know in a Super Duty they wind it up pretty tight to redline
Old 03-29-2014, 02:25 PM
dualwheels66's Avatar
dualwheels66
dualwheels66 is offline
Let that thing rev, its built to do just that. There is good torque right around 3k rpm's, there is even more around 4k. Around 5k it runs out of breath but you really don't need to go that high. Experiment with certain speeds in OD and lock out OD and do some more experimenting. Depending on your rear gear ratio and weight of your RV you might have different results than others with a lighter RV and different gears. Also that engine wont break in until you roll over 5000 miles.
Old 03-29-2014, 02:52 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,576 Likes on 1,054 Posts
Dad was told by someone that didn't know what they were talking about.
The computer will let the engine run at any RPM that is safe for it. It will not allow the engine to run at a speed that could cause damage. The computer is very smart in that regard.
Old 03-29-2014, 03:48 PM
Hank85713's Avatar
Hank85713
Hank85713 is offline
I havent installed it yet, but I got a tuner from 5 star which is supposed to help this situation out. I dont like the high rpms and lack of throttle control that the engine offers and when I contacted 5 star the owner responded that his tuner would make the engine operate better and with less rpms.
I would have your dad contact 5star with his concerns and get the answer direct. 5 Star has good reputation and has positive feedback on this and other forums, just FYI.
Old 03-29-2014, 05:35 PM
scraprat's Avatar
scraprat
scraprat is offline
Received 2,496 Likes on 1,305 Posts
These v10s are stout engines he won't hurt it going 3000+ rpms that computer won't let it blow. Tell him enjoy the camper and stop listening to who ever is giving him bad info.
Old 03-29-2014, 05:42 PM
pappy19's Avatar
pappy19
pappy19 is offline
A Mike's 5 Star will wake that MH up for sure. As stated, no problem up to 5k rpm's and over.
Old 03-29-2014, 10:34 PM
petrokiller
Thanks everybody, I sent a link to the post for him to review.
Will pass on any info he give's. Definetely get the consensus he should just Hammer down on the go pedal.
I like the experiment idea so see how it reacts. The gear ratio is probably 4.10 or lower.
Think he said it gets 8-8.5 on a good day. No doubt the engine is strong, they tow a Honda CRV also.
Take care
Old 03-30-2014, 07:11 AM
dualwheels66
Your rear gear ratio could be 4:56, 4:88, 5:13 or 5:88 and there might even be a 5:32 in there some where. A tuner from 5star will get rid of that throttle lag and help the trans with quicker and crisper shifts.
petrokiller
1999 to 2016 Super Duty
26
03-30-2014 11:48 AM
airride41
Modular V10 (6.8l)
10-24-2007 01:31 PM
RagdollRacer
Toy Hauler Towing; Fifth Wheel & Bumper Pull
06-12-2007 01:59 AM
4x4x4x4
07-17-2002 07:04 PM
spridget
04-25-2001 01:46 AM
Quick Reply: 2012 V10 in Motorhome help with rpm
