Carling switch pin breakdown
So I hope that this doesn't confuse anyone. I have no problems answering any questions and plan on cleaning all this up soon so it's more professional.
Some rough sketches of my wiring diagram.
The dome/floor light switch is a 3 way switch. off/on/on (off / floor lights / dome light)
No need to pay attention to "actual colors on truck" those are just my notes of what colored wires I used. Did the sketch before I ordered wires.
[/URL]
[/URL]
If the picture in the OP does not accurately represent what Clay sends, disregard the following:
Whoa! Putting a pause on things here:
The switch in the picture has 4 terminals. All the diagrams show 5 terminals or more.
I looked at the whole Carling catalog - cool products, complex options, and missing data on this switch.
I have installed many lighted switches, and the light typically gets its power from the load side of the switch... meaning no light dimmer.
With conflicting info, my gut is telling me the three terminals in a row are single-pole double-throw. Power would go to the middle terminal, and the load would go on one of the two end terminals. One of the end terminals is attached to one end of the LED, and that one lone terminal to the side is ground for the LED.
Oh... side note: Check this out.
https://www.youtube.com/watch?v=EySK...ature=youtu.be
I have a test - 12V on the center terminal of the three in a row. Ground to the straggler not in line. Flip switch. If the LED lights up, my gut was right.
Here's the post:
Here you go Clint, sorry I didnt see this thread sooner.
now, what this diagram doesn't tell you is that you need to daisy chain your switches together, if you are running mor ethan one switch. that way you only have to have one positive wire, one ground wire, and one positive illumination wire running to one switch and then you can wire the switches in series to all use the same power and ground wires...... Clear as Mud?
#8 connects to Illum +, and then run a jumper to the #8 pole on the second switch, and a jumper to the #8 pole on the third switch.
#7 connects to ground -, and then a jumper to #7 pole second switch, and a jumper to #7 pole third switch
#2 connects to 12V+ switched power, and then a jumper to second switch #2 pole, and then jumper to third switch #2 pole.
#3 pole is your output to what ever ACC you are using the switch for. DO NOT DAISY CHAIN # 3 POLE.
Thanks for the help, info & diagrams guys - gonna try and get this all finished today since it's gonna be nice out today (65 degrees!) and I won't have to hide in the garage with the heater.
Rich (Tugly), yep - the switches I ordered are the ones I posted the pic of in my OP. I tried to decipher the technical diagrams on Carlings website - but after 2 beers it was too much for my brain at the time..... You can order any type of switch through Riffraff when ordering the F650 dash kits but I just needed the easy & simple on/off switches - but the switch on lamp and the background LED through me off I guess.......
Either way I need to finish today since more snow is coming Monday g
Clay does a nice job with his products - doesn't he........
Can't believe it has taken me 3 years to get this stuff done on the Excursion. Boy, that fuel pressure gauge sure got more eyeball time than any other gauge this incredibly cold winter . It sure is nice to have it finally mounted instead of dangling from the dash.....
Thanks everybody - got her all buttoned up before the next round of snow is due to hit.
