Need Help...How do I wire carling switches?
So I've got my F650 dash ready to be installed. I've got all of the guages and switches in it and it is ready to go in the truck right after I wire it. I need to know how to wire the carling switches. If someone could tell me what each of the poles that come out of the back of them are or show me a wiring diagram, that would be great. I know that some ppl have already done this mod so maybe even a pic of yours from the back would help.
Depends on what switches you get and what you want them to do.
Maybe this will help
http://www.carlingtech.com/pdf/Wirediagrams.pdf
Here you go Clint, sorry I didnt see this thread sooner.
now, what this diagram doesn't tell you is that you need to daisy chain your switches together, if you are running mor ethan one switch. that way you only have to have one positive wire, one ground wire, and one positive illumination wire running to one switch and then you can wire the switches in series to all use the same power and ground wires...... Clear as Mud?
#8 connects to Illum +, and then run a jumper to the #8 pole on the second switch, and a jumper to the #8 pole on the third switch.
#7 connects to ground -, and then a jumper to #7 pole second switch, and a jumper to #7 pole third switch
#2 connects to 12V+ switched power, and then a jumper to second switch #2 pole, and then jumper to third switch #2 pole.
#3 pole is your output to what ever ACC you are using the switch for. DO NOT DAISY CHAIN # 3 POLE.
