Do 5.4L sound like diesels?
Hello-
Been looking for a truck to pull a TT/5er. Decided on a gasser.
I looked at a 2005 F250 Lariat, 4X4, CC, LB, 48K miles. Has the 5.4L. Truck is in good shape. Original owner. He never towed anyting.
Question: Does the 5.4L have a diesel sound to it? This truck at idle sounds like a diesel! Both the owner and my buddy agreed as we listened to it.
How is this truck for pulling a 8-9K TT or 10K 5er? Is the 5.4L reliable?
Thanks
Thanks
they tend to sound like diesels when the cam phasers are going south. AFAIK, that diesel sound is the timing chains flailing about behind the timing cover, but someone will correct me if i'm wrong.
get it looked at before you buy it, or leave enough money on the table to get it fixed if you buy it as-is. generally, phasers will cost you in the 1,000 - 2,000 range to get replaced.
on a 2005, phasers are a known problem.
jmo.
jmo.
Hello-
Thanks
Thanks
I would look elsewhere unless it is an incredible price.
after reading the bulliten from ford about switching to 10W40 if the ticky tick phasor noise is a complaint...I switch ed to 5W40 and the ticky tick has been masked. if that didn't work, I was going to do the washer mod to the pahsors...basically a washer with a small hole replaces a part in the phaser that has a larger hole...the reduction in hole size keeps oil back pressured in the phasor and quiets them down.
My truck has 87K now which is 3K miles later from when I bought it.
Toreador_Diesel
6.7L Power Stroke Diesel
10-04-2009 11:39 AM
