Help Finding Shoe Retracting Assist Spring
Does any one know where a Shoe Retracting Assist Spring 2035-6 can be found for 64 F100 2x4 front brakes. It is not in inclued in the hardware kits. Goggle search said it optional depending on who is posting, but it is there to prevent heat glazing which my problem.
The brakes work well the first time or so then start pulling to the right. All parts are new (except the drums) and I replaced a hard line that was too close to the exhaust. I have disassembled and reassembled the brakes and it has improved and keeps improving with driving. I would like to add the spring to know it is as it came from the factory. Henry Ford was thrifty and I can not believe he added unneeded parts to a vehicle.
The highlighted long retracting spring that extends from the primary to the secondary brake shoe is:
C3AZ-2035-A = 1966/75 F100 4WD R/L Front/Rear / 1976 F100 4WD R/L Rear / 1975/91 F150 4WD R/L Rear.
The following springs should be available from any auto parts store, as these fit multiple applications.
For y'all that live in TX and want genuine Ford parts, NOS PARTS LTD in Waxahachie (972-937-2201) has 15 each of these C0MM springs.
C0MM-2036-A .. Primary Brake Shoe Retracting Spring-Red.
C0MM-2035-A .. Secondary Brake Shoe Retracting Spring-Black.
1964/72 F100 2WD R/L Front/Rear / 1973/83 F100 2WD R/L Rear / 1975/91 F150 2WD R/L Rear
1960/64 full size Mercury R/L Front/Rear / 1961/66 Galaxie R/L Front/Rear / 1967/75 Bronco R/L Front/Rear / 1976/91 Bronco R/L Rear.
Thank you Bill and Arctic Y Block. I'll take the old truck and my young boy's for a ride to NAPA and see it they can cross reference C3AZ-2035-A. Or see if it is in a hardware kit for 1966/75 F100 4WD. It is odd that is not listed for the 64 2WD because the picture is from the 64 shop manual. I may not have the right picture in the parts book. Bill, I am getting better but still struggle. Your help is greatly appreciated. Thank you again.
Even if it was not original, My shoes are dragging slightly and glazing over on driver side. The assist spring is supposed to prevent that. If I can not find them, the brake shop has two that are 1/4 inch too long. Maybe I can shrink them somehow.
Parts catalog pic is for 2WD & 4WD, P100 (P Series Parcel Delivery) & E200 (1969/72 3/4 ton Econoline).
But, when you look in the text section at the parts list (#2), it lists the specific applications.
To list the various applications for secondary and primary springs (C0MM-2035-A & C0MM-2036-A) in post 8, I had to look in 5 car & truck parts catalogs.
Left: Applications / Right: Parts List #2
TomsBeast
28
05-14-2020 10:02 AM
