tallest tires with no lift
Old 03-04-2014, 05:03 PM
madcatter33's Avatar
madcatter33
madcatter33 is offline
I am looking into a new tire/wheels combo on my 2012 F150 xlt ecoboost. I have no lift whatsoever...Im looking at aftermarket wheels and either Nitto trail grapplers or wrangler mtr's...I want a tall tire and doesn't need to be wide...Any real answers on this? Thanks in advance
Old 03-05-2014, 06:28 AM
'78F250351m's Avatar
'78F250351m
'78F250351m is offline
What size rim? From the research I've done, I think 285/65/18 may be the largest you can go stock. My buddy has this size Terra Grapplers with no lift and no issues. I have Trail Grapplers this size that I'm installing with a 2" autospring once my first set of tires are gone. If your running 20's not sure wat size you can go up to.
Old 03-05-2014, 07:49 PM
madcatter33
Was sure hoping to go with 20's
Old 03-05-2014, 09:14 PM
MCDavis's Avatar
MCDavis
MCDavis is offline
20's, no level...well this depends on a lot, especially your offset on the new wheels.
Stock 20's are a +44mm offset. You should avoid most rubbing situations if you stay between +44mm and +18mm with these tire sizes:
275/60/20
285/55/20
285/60/20
295/50/20
295/55/20
You'll need a level to fit these popular sizes:
275/65/20
285/65/20
295/60/20
Old 03-06-2014, 02:56 AM
madcatter33
Guess I will be looking for a 2" leveling kit as well... Thanks
Old 03-10-2014, 10:09 AM
Stangfire's Avatar
Stangfire
Stangfire is offline
You can fit 33" diameter tires, 295 wide with no lift or level.
Old 06-04-2015, 08:14 AM
Turbo Dog's Avatar
Turbo Dog
Turbo Dog is offline
I'm looking at putting on LT275/70R18 on stock rims on a 2013 FX4 without any lift or leveling kit. Those should be 33.23" tall. So...they'll fit?
Old 06-04-2015, 09:50 PM
AlaskanEx's Avatar
AlaskanEx
AlaskanEx is offline
Bleed Ford Blue
I've got 305/45R22 Nitto Terra Grapplers with no rubbing anywhere. Overall is 32.8" and they are a little over 12" wide, Truck is all stock.
noimports
2017+ Super Duty
02-17-2017 09:27 PM
FordTrucksGirl93
10-23-2014 03:19 PM
Insane Wheeler
1999 to 2016 Super Duty
18
08-29-2008 11:12 AM
fordtrck302
08-27-2004 07:05 PM
Quick Reply: tallest tires with no lift
