another quick question.
Hello all...
I am swapping an OBS engine (96) into my 2000 SD. I've already swapped all the parts from my SD to the Obs long block, including motor mounts, swamps 175/146 injectors, Hpop, A/C and alternator brackets, etc etc. I was planning on dropping the engine in tomorrow but just noticed the dip stick is different. The OBS dipstick is shorter and exits around the A/C evaporator unit. Just by simply measuring, it seems I might be able to leave it as is.
My question is:
Will the IC tube be in the way of the dipstick? Will I have to drop the pan and swap dipsticks??
Thanks
My question is:
Thanks
The dipstick should just snap into the base like it does on the newer style. Leave the part that is bolted into the side of the pan and look for the joint. There's an o-ring in there that keeps it sealed. Pull the one apart from your SD motor first so you can see.
You did change the intake plenums and exhaust manifolds too, right?
Ok. Gotcha. I will give it a shot.
Yes... I replaced pretty much everything from the SD engine over to the OBS. So essentialy I started off with an OBS long block.
The only thing I did not change was the front cover; as they looked identical. The only difference I could see was the HPOP reservoir on the OBS does not use a screen. Not sure if it is absolutely necessary to run it. Should I???
Ask the OBS guys if it's worth messing with then. Seems to be a rare problem, but it's a possibility.
Also, which oil cooler are you using? I don't remember exactly when they changed, but with a 96, there's the chance you have the staked bypass valve instead of the updated c-clip. It's the little hole with something in it on the plate where the oil filter screws onto. The c-clip is way better since the staked valve sometimes falls out and then you have no oil pressure to start the engine.
I will have to check the oil cooler but I believe it is the same as the SD one.
Reason I used the OBS cooler is because my SD cooler got contaminated with oil/fuel sludge.
I didnt know about this issue, but if memory serves me well it was the C-clip type. I'm pretty sure they looked identical when I put new orings in it...
The dipstick adapter flange inside the oilpan has alignment notches on it that mate with the oilpan... the obs dipstick tube goes basically str8 up while the sd's cant toward the front of the motor. I honestly do not remember if i had to physically swap them, or if i was able to rotate the flange that was already there.
Would be a good idear to pull the pan on the one going in anyway to peek in and make sure no piston cooling jets are missing.. look at cylinder walls, cam lobes, etc...
Best to do it now rather than later and have to pull it back out. If i pull a motor, the pan IS coming off...
Mark, thanks for the heads-up... i need to re-up my membership.
bjmayberry2
17
03-14-2016 05:15 PM
52' fordnut
11-12-2012 06:34 PM
DT 466Man
12-27-2006 09:17 PM
pickndblues
11-15-2002 10:21 AM
