Dipstick location???
Old Nov 11, 2012 | 06:26 PM
52' fordnut's Avatar
52' fordnut
Hello,
I have a 302 that currently has the dipstick on the left side of the engine. I want to put a chrome dipstick tube on the engine and have seen several images of 302's with the dipstick at the front of the engine. Anyone have any advice on maybe the repositioning of the dipstick tube from the side to the front?
Any help is appreciated!
Jon Preston
Old Nov 11, 2012 | 06:57 PM
81ChopTop's Avatar
81ChopTop
Usually the engines that have front dipsticks are from Mustangs, T-Birds, etc.. They all have a front sump or dual sump pans. If you have a rear sump, you'll have to stick with the side stick, but if you are going to switch to one of the other pans, you can go to a front stick.
A question though, is the current dipstick through the pan or block?
Old Nov 11, 2012 | 07:19 PM
52' fordnut
Hello,
It's actually through the block. The engine came from a 1980 ford f150.
Thanks again!
Jon Preston
Old Nov 11, 2012 | 08:20 PM
Franklin2's Avatar
Franklin2
If you are still using the dipstick, then you must have the rear sump pan still on it. Can't move it to the front.
Old Nov 12, 2012 | 09:25 AM
Sw1tchfoot's Avatar
Sw1tchfoot
As said above, you don't want a front dipstick. I have a front dipstick on the passenger side, going into the timing cover. The oil level varies too much, it has to be completely level to get an accurate reading. (If it is even accurate).
Old Nov 12, 2012 | 06:34 PM
1983F1503004x4's Avatar
1983F1503004x4
Some of the dipsticks I see are in the cab. The way some of 'em act, I wonder if their oil levels are low.
You could get a chrome dipstick handle and put on there. I think LMC sells one.
choppermanjapan
13
Mar 20, 2016 09:36 PM
spikinfool05
Nov 10, 2012 03:35 PM
f250red
Jun 27, 2006 06:30 PM
jds1971
May 19, 2002 09:59 AM
Curtis360
May 19, 2002 09:48 AM
