6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
BOOST! How much is too much?
Old 02-22-2014, 10:39 AM
Jusitinj608's Avatar
Jusitinj608
Jusitinj608 is offline
On stock engine, with new S&B intake, H&S set to Hot Damn300, final run on trans relearn at 99% throttle she went to 45lbs! I'm guessing that if I leave it at that setting and drive it like I stole it(cause it's that much fun) that I may as well start lifting cab off right now? Any thoughts or personal experience on this topic?
Old 02-22-2014, 11:18 AM
bubbasz1's Avatar
bubbasz1
bubbasz1 is offline
Stock max from the factory is 41 lb's if I remember correctly. Set your defuels below the max so that doesn't happen. Personally I have my set at 33 Lbs. No particular reason other than that's more than enough for city driving.
Old 02-22-2014, 05:20 PM
RM2738's Avatar
RM2738
RM2738 is offline
H&S says 45 is OK periodically. Personally, my Defuel setting is at 32. No reason to exceed that in my opinion.
Old 02-22-2014, 05:32 PM
UGA33's Avatar
UGA33
UGA33 is offline
The Borg's on the 6.4 are pretty stout. Mine saw 52 psi a couple of times. My buddies 6.4 on 40" tires sees 50+ all the time. No need to worry about 45 psi for the turbos, it's the head gaskets that will hate it, especially if back pressure is high.
Jusitinj608
Ya, I went back out and looked and the defuel for boost was off, oops! I now set it at 40, probably should take it down more, but I feel there is a reason to keep it up pretty good- POWER! It is wild when it is fully lit!
Old 02-22-2014, 05:37 PM
UGA33's Avatar
UGA33
UGA33 is offline
40 would be a nice place to leave it.
Old 02-22-2014, 05:49 PM
senix's Avatar
senix
senix is offline
Received 1,459 Likes on 1,041 Posts
41PSI is max. I ran that many times but anymore than that and you run the risk of lifting the heads.
Old 02-22-2014, 05:52 PM
Jusitinj608
UGA33- I assume your buddies with the big tires has a built motor? Or at least studded heads?
Old 02-22-2014, 05:58 PM
Jusitinj608
10-4 SENIX, I won't push it too much.
I got no problem with the fact that soon cab is coming off to stud it and take care of some other known issues such as unknown oil leak on driver side upper bank and little leaky up pipes(could sometimes smell raw diesel in cab pretty bad when regen would begin) but, would like to wait till summer
Old 02-22-2014, 06:11 PM
UGA33's Avatar
UGA33
UGA33 is offline
My 6.4 was studded and his is also. That's it. Both of us hit 50+ psi on non studded heads with no puking but when heads were taken off they were both a couple more hard runs from blowing. Wish I would have taken pics.
davesbb4x
1999 to 2016 Super Duty
06-18-2012 07:59 PM
GDAWG 2012XLT
6.7L Power Stroke Diesel
02-03-2012 11:25 PM
dyoung14
53
11-26-2010 10:38 PM
derbinator
06-10-2010 07:13 PM
farmb0y
25
09-12-2004 02:46 PM
Quick Reply: BOOST! How much is too much?
