1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
99 F550 Flashers don't work
Old 02-20-2014, 02:37 PM
Cole Neese's Avatar
Cole Neese
Cole Neese is offline
Exclamation 99 F550 Flashers don't work
My dad has a 99 F550 with a 7.3 and the flashers won't work. The turn signals work just fine(normal speed) but the flashers don't do anything. I changed the flasher relay and that didn't do anything. I found the fuse for it in the passenger compartment fuse box (fuse #1) and it was fine. What stumped me is that the fuse only gets 0.49V according to my multimeter, maybe a bad connection but I got the same result 5 times, on the "2V" scale. When I put the fuse back in the relay goes through one cycle and then stops, so instead of going click-Click-click-Click-etc it goes click-Click-nothing. Any ideas what this may be? I'm not exactly good with the electronics on newer vehicles so I'm stumped. Thanks for any help.
Old 02-20-2014, 10:31 PM
Cole Neese's Avatar
Cole Neese
Please help? I really need to fix this we farm and the flashers get used a lot. They didn't work when we bought the truck so I don't know when or how they went out.
Old 02-20-2014, 11:57 PM
Ravenwood Ranch's Avatar
Ravenwood Ranch
Ravenwood Ranch is offline
i would pull the relay and check the connections if there clean i would run a meeter through and make sure that it is engaging
Quote from UNBROKEN
t's down low...behind/below the radio in the center of the dash.
Reach up towards the radio from the gas pedal area. The easiest way to find it is to turn on the blinkers and feel for the relay that's clicking.
Old 02-21-2014, 07:56 AM
Cole Neese's Avatar
Cole Neese
Quote from UNBROKEN
I did, I pulled it and the connections were clean so I replaced it and that didn't do anything. What should the meter say on the different connections for the relay with the flasher on? I wondered about checking it but not knowing which circuit is which I figured it wouldn't help much. I kind of wondered if it could be the switch in the steering column?
Old 02-22-2014, 06:27 PM
Cole Neese's Avatar
Cole Neese
Help please?
Sberry27
Electrical Systems/Wiring
10-16-2014 07:32 AM
73f100shortbed
Bronco II
07-18-2006 06:50 PM
Tony711
1997-2006 Expedition & Navigator
06-23-2003 10:37 PM
Quick Reply: 99 F550 Flashers don't work
