Windstar parasitic draw
Old Oct 13, 2014 | 09:26 AM
Sberry27's Avatar
Sberry27
It draws about 3/4 of an amp. Goes away when we pull every fuse and seems to be a combination of them that cause this? What are SSP fuses, there are 4 of them.
Old Oct 13, 2014 | 03:04 PM
Franklin2's Avatar
Franklin2
Don't know what a SSP fuse is. Do you know what the fuses are that make it go away? If it's a group, I suspect it might have something to do with the accessory delay relay. Find this relay and pull it, and see if the draw goes away. If it does, you might have to wait about 30 minutes before doing any testing, to make sure the accessory delay relay is off. This is the relay that lets you play the radio and roll the windows up and down after you turn the key off.
P.S. .75 amps is way to high in case you are wondering. It should be no larger than .075amps.
Old Oct 13, 2014 | 09:48 PM
projectSHO89's Avatar
projectSHO89
AFTER the module times out, usually 30-45 minutes.
Old Oct 14, 2014 | 12:44 PM
Sberry27's Avatar
Sberry27
Thanks for the help. I think I got it now. I didn't realize how it worked.
Old Oct 15, 2014 | 07:37 PM
ROADHOGE250's Avatar
ROADHOGE250
SSP ?
The SSP are connected to an after market stereo system ?
Could be SSP are relays or under the hood next to brake fluid
Ford Windstar SSP fuses - Google Search
Old Oct 16, 2014 | 07:32 AM
projectSHO89
"Switched System Power"
Those are circuits that are turned on when they're supposed to, off when not.
Since you didn't identify the year of your Windstar, it's not possible to provide specifics.
StillNotKing
21
Sep 28, 2021 08:19 AM
Abear375
1997 - 2003 F150
Nov 11, 2018 01:56 PM
budlightman11j
Jul 31, 2013 07:52 PM
jbain
Jun 11, 2011 10:17 AM
Diesel 724
Nov 1, 2010 12:16 PM
