Disc Brake conversion, labor hours
I got all my essential brake parts to convert my 1960 F100 from the original front drum brakes to a power boosted disc brake set up. Also replacing king pins, tie rod ends and all my shackles and pins on the original front leaf spring set up.
I got all my parts set up to go, read some articles and basically said to myself, "Ain't nobody got time for that." and I think about all the deer that run by this time of year, and felt..."Better leave it to the professionals"
There is a very decent shop nearby with favorable labor rates that has always been good to us who actually does full car restorations aside from its general maintenance and repair and tire business. Currently they are restoring two drive trains on some 1960's cars.
Of course I got the "time and materials" response which I expected but have not been able to get even a rough estimate. My hot rod friends say maybe 6-7 hours plus all that brake line time.
Any thought to this?
6-7 hrs. maybe if your friend is doing it. Many shops these days don't do very many king pins, some don't have the reamers to install the bushings for the spindles. Make sure you ask them about that. Just the large truck shops around here have that stuff. I would not be surprised if they charge the better part of two days.
Well, if that's all then, just go for it! Pull the whole axel out where you can get to things and then just heat and beat! Some determination required. You will still need to find someone that can fit the spindle pins though. Your best bet would be a big truck shop, like where they work on dump trucks and tractor trailors etc...
sublauxation
12-12-2017 02:49 PM
jerryst
10-20-2011 05:25 PM
Eston Newbern
16
09-16-2010 08:30 AM
Matt67
12-10-2001 11:53 AM
