SRS Code 46
Old 12-08-2009, 08:21 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
SRS Code 46
Can anyone tell me what a code 46 means?
Old 12-08-2009, 08:38 PM
michigan66's Avatar
michigan66
michigan66 is offline
What truck do you have; what engine? From the vehicle list you have, i'm wondering if you shouldn't be posting your request under a different heading. Rangers usually have either 3 or 4 digit trouble codes.
Old 12-08-2009, 08:43 PM
Diesel_Brad
O i am sorry. I just got an 04 ranger 4.o 5spd 4x4 on sat. I havent updated my profile yet. And the SRS light blinks 4 times then 6 times then starts over again
Old 12-09-2009, 09:32 AM
pawpaw's Avatar
pawpaw
pawpaw is offline
Welcome to the Ranger & B-Series forum.
This is about all I could find on the code 46.
It seems to have to do with high or low resistance in the drivers side seat belt tensioner sensor, or the system having recently been disconnected with the vehicle power on. If the latter was the case & the computer doesn't detect another problem after something like 256 start cycles, the SRS computer will finally clear the code & turn the light off.
OR, you could disable your fuel pump, so it wont cycle on, & turn your ignition key from off, to run, without cranking the engine, enough times (256) & it'll clear the code & turn the light off.
OR a Dealer, or shop with a scantool that'll access the SRS system can do it.
Let us know what you find.
Old 12-09-2009, 09:43 AM
Diesel_Brad
Thanks pawpaw
Old 12-09-2009, 02:20 PM
Areyouforcereal?'s Avatar
Areyouforcereal?
Areyouforcereal? is offline
Check the connector under the seat. unplug it, check for corrosion or a loose fit, plug it back in. Should fix you problem. I had this issue with the psger, side.
Old 12-09-2009, 04:25 PM
Diesel_Brad
thanks for the replies guys. The PO looks like he used a garden hose in the truck to try and clean it So corosion would not be out of the question
Old 01-02-2010, 01:57 PM
Diesel_Brad
Ok. so i got to looking at the drivers seat today. I found why i have the SRS code. The PO ripped the connector right off the harness. Both sides are missing(seat and truck) I am Just going to but connector the wires to their respective match. Does anyone have a pic or diagram of where they go? I would like to get the truck inspected, and its a no go with the SRS on
Old 01-02-2010, 11:11 PM
Rockledge's Avatar
Rockledge
Rockledge is offline
If your '04 is the same as an '02, then here's what you're looking at:
Pretensioner Connector
Pin 1 = (BK) Ground
Pin 2 = (LG/BK) Driver safety belt retractor pretensioner, return
Pin 3 = (BN/LB) Safety belt buckle switch (10B924), input
Pin 4 = (LG/RD) Driver safety belt retractor pretensioner, feed
Pin 1 eventually gets grounded to the vehicle floor.
Pins 2 & 4 run to the Restraints Control Module (pins 22 and 18, respectably).
Pin 3 runs to the GEM (pin 5)
Old 01-03-2010, 11:04 PM
bigrigfixer's Avatar
bigrigfixer
bigrigfixer is offline
The Pacifier
You've obviously found your problem, but do keep this in mind.
When you open the suicide doors, make sure they close properly, because the belt tensioner is in the suicide door.
Old 12-13-2015, 08:43 AM
Diesel_Brad
Ok, I'm back at this again since I am FINALLY putting the truck together after pretty much a frame off resto
The seat side harness has ..
(2)red /white tracer
(2) black /white hashes(at least thats what it looks like)
And no connector
The truck side...
red
red /green tracer
red /black tracer
Black
Suggestions on how to connect them?
Old 12-13-2015, 12:08 PM
reddog99's Avatar
reddog99
reddog99 is offline
I searched in my 2004 shop manual, and let me tell you, they don't make it easy to find anything. There's lots of chapter headings that are just numbers and the only way to find anything is to open every page. I found the connectors for the belt sensors, so I hope this is what you need. Let me know if I can help more. I think I'm slowly learning how to navigate this mess.
File Type: pdf
File Type: pdf
Old 12-13-2015, 07:37 PM
Diesel_Brad
The second link has the truck side connector C3014
I actually found someone with an 04 that was able to give me the color to color match.. I'll post my results in the AM
But thank you VERY much
Old 12-16-2015, 09:00 AM
Diesel_Brad
OK. this is for an 04. Not sure if other years are the same
And this is the driver side
Truck side...........Seat side
Green.................Black
Green/Red..........Red/white
Green/Black........Red/white
Black..................Black
pdrhodes1
13
06-08-2016 03:22 PM
Rick Henson
1997 - 2003 F150
03-04-2016 11:01 PM
RW1998
1997-2006 Expedition & Navigator
02-06-2016 06:50 PM
RW1998
43
01-23-2016 04:57 PM
saltydog463
01-19-2016 09:12 AM
Quick Reply: SRS Code 46
