What truck do you have; what engine? From the vehicle list you have, i'm wondering if you shouldn't be posting your request under a different heading. Rangers usually have either 3 or 4 digit trouble codes.
O i am sorry. I just got an 04 ranger 4.o 5spd 4x4 on sat. I havent updated my profile yet. And the SRS light blinks 4 times then 6 times then starts over again
Welcome to the Ranger & B-Series forum.
This is about all I could find on the code 46.
It seems to have to do with high or low resistance in the drivers side seat belt tensioner sensor, or the system having recently been disconnected with the vehicle power on. If the latter was the case & the computer doesn't detect another problem after something like 256 start cycles, the SRS computer will finally clear the code & turn the light off.
OR, you could disable your fuel pump, so it wont cycle on, & turn your ignition key from off, to run, without cranking the engine, enough times (256) & it'll clear the code & turn the light off.
OR a Dealer, or shop with a scantool that'll access the SRS system can do it.
Check the connector under the seat. unplug it, check for corrosion or a loose fit, plug it back in. Should fix you problem. I had this issue with the psger, side.
Ok. so i got to looking at the drivers seat today. I found why i have the SRS code. The PO ripped the connector right off the harness. Both sides are missing(seat and truck) I am Just going to but connector the wires to their respective match. Does anyone have a pic or diagram of where they go? I would like to get the truck inspected, and its a no go with the SRS on
I searched in my 2004 shop manual, and let me tell you, they don't make it easy to find anything. There's lots of chapter headings that are just numbers and the only way to find anything is to open every page. I found the connectors for the belt sensors, so I hope this is what you need. Let me know if I can help more. I think I'm slowly learning how to navigate this mess.
The second link has the truck side connector C3014
I actually found someone with an 04 that was able to give me the color to color match.. I'll post my results in the AM
