Sponsored by: Auxito
03' F150 SES Light: code P0171
Old Mar 4, 2016 | 08:20 PM
Rick Henson's Avatar
Rick Henson
The "service engine soon" light on my 2003 F150 Supercrew 4.6L (225k miles) just came on. The code it's throwing is P0171. Any suggestions?
Old Mar 4, 2016 | 08:43 PM
Bluegrass 7's Avatar
Bluegrass 7
Have you looked up the code description?
First place to begin if your going to solve the problem.
Good luck.
Old Mar 4, 2016 | 10:29 PM
Rick Henson
Good luck.
The code says "System too lean bank 1" The guy at the auto parts store I go to said it could be any one of several things. I just thought that maybe, this being a message board for Ford truck enthusiasts, someone might know a common cause for this so I might have a good place to start.
Old Mar 4, 2016 | 11:01 PM
Bluegrass 7
What I am trying to do is get you to begin helping yourself to understand what the code is.
Your man at the store was no help.
The code tells you bank one is getting to much air from an air leak. 'Lean'
It is being detected by the OX sensor in the exhaust for that bank. The passenger side.
The code is set because the Long Term Fuel table for that bank has shifted 'rich' trying to account for the excess air.
When the shift gets over 25% the code is set and MIL lamp comes on.
Most of the time the cause is an air leak from faulty rubber hoes or parts in the PCV system.
Check out the hose and fitting from the passenger side valve cover to the rear of the intake manifold where it terminates.
On the back of the intake, you cannot see it very well so feel for softness or other signs of an issue.
I just thought you should know what your working with.
Good luck.
dacrew4009
1997 - 2003 F150
Jan 28, 2014 10:20 PM
JP Hobbit
1997 - 2003 F150
Apr 7, 2013 12:52 PM
99EdeBauer
Jul 31, 2008 07:06 PM
clifftown2000
1997 - 2003 F150
Dec 5, 2006 04:52 PM
rmarion
1983 - 2012 Ranger & B-Series
Sep 7, 2004 09:04 AM
