66 4x4 body shot, want new bed+body what year?
Old 01-27-2014, 07:23 PM
mse871859949's Avatar
mse871859949
mse871859949 is offline
Hello again FTE, love this place. I've got a couple 4x4 fords a, 79 and a 66 4x4 f100 w/ twin I beams. The 66 is all crinkled and beat (no rust but beyond repair dents). The running gear is great, no leaks, strong 352, 4x4 works. It is a long bed.
Question, I want to swap out the bed and cab for another cab and bed. What years will work?
Bolt patterns/frame width etc?
All I can foresee a difference is the hole for the transfer case shift lever?
I want to keep it pre- 1966, I prefer the older body style.
Thanks
<a href="http://s1186.photobucket.com/user/mse871859949/media/IMG_2481_zpsd7f7e0dd.jpg.html" target="_blank"><img src="http://i1186.photobucket.com/albums/z362/mse871859949/IMG_2481_zpsd7f7e0dd.jpg" border="0" alt=" photo IMG_2481_zpsd7f7e0dd.jpg"/></a>
<a href="http://s1186.photobucket.com/user/mse871859949/media/IMG_2489_zpsf6b2893b.jpg.html" target="_blank"><img src="http://i1186.photobucket.com/albums/z362/mse871859949/IMG_2489_zpsf6b2893b.jpg" border="0" alt=" photo IMG_2489_zpsf6b2893b.jpg"/></a>
Old 01-27-2014, 09:16 PM
EricJ's Avatar
EricJ
EricJ is offline
65-79 are pretty much the same. , and the 4x4 is not a twin I beam, the twin I beam is the front suspension on the 2wd's from '65 forward..
Old 01-27-2014, 09:49 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
1965/66 F100/250 2WD & 1966 F100 4WD use the same cab and Styleside beds.
1964 F100/250 2WD's use the same Styleside beds as above.
1966 was the first year that F100 4WD's came with coil spring front suspension.
Old 01-27-2014, 09:59 PM
mse871859949
Thanks for the clarification on the twin i-beam! Numberdummy, always spot on. I am interested in the pre 1966 body, if anyone knows a good donor truck or bed/cab in the west please let me know. Sounds like 66 and 65 will work best. Thanks all
Old 01-28-2014, 04:43 AM
EricJ's Avatar
EricJ
EricJ is offline
I dropped my 65 2wd shorty on a 1979 F-150 4x4 shorty chassis a couple of years ago. The cab bolted right on, but when I tryed to mount the bed I had to make a slight modification to the rear of the frame, I should have pix if you 'd like to see it. And after the mod I had to lift the bed 1" to clear. So I grabbed a hadfull of hockey pucks and used those for a mount lift for the cab and bed. Was a really easy swap. I used my old 390 so I had to fab up some mounts as well, but that wasn't a big deal either.
Old 01-29-2014, 08:34 AM
bertha66's Avatar
bertha66
bertha66 is offline
I used a 65 F100 2wd body on my 66 F100 4x4; the 65 was a automatic trans truck, so I had to cut the floor pan out to fit the 4sp and transfer case shifters. Also the radiator core support is a bit different on a 4x4, so save your old one. I can not remember if the inter fenders are different or not. And when I changed out he radiator; I got a radiator for a 2wd and had to have the mounting brackets removed and the core turned around and put back together.
Old 01-29-2014, 09:25 AM
NumberDummy
Originally Posted by bertha66
I used a 65 F100 2wd body on my 66 F100 4x4. The radiator core support is a bit different on a 4x4, so save your old one.
You sure it was a 1965 F100 2WD body and not one from a 1966?
B9TZ-8005-K .. 352 Radiator ~ 1965 F100/250 2WD & 1966 F100 4WD
C5TZ-16054-C Right & C5TZ-16055-D Left .. Inner Fender Aprons ~ 1965/66 F100/250 2WD & 1966 F100 4WD
C6TZ-16138-C (replaced C5TZ-16138-B) .. Radiator Support ~ 1965 F100/250 2WD & 1966 F100 4WD
1966 F100/250 2WD uses a different radiator and radiator support than 1965 F100/250 2WD & 1966 F100 4WD
Old 01-29-2014, 09:38 AM
bertha66's Avatar
bertha66
bertha66 is offline
Yes, it was a 65 2wd truck, I still have the 65 grill and fender emblems off of it. And the title said 65.
Old 01-30-2014, 07:53 PM
ddub's Avatar
ddub
ddub is offline
I have a 65 4x4 cab with good floors ...small amount of cancer in the lower bottom corners...150.00 20 miles north of Portland or...
snortf100
98
12-17-2023 12:23 PM
eminencefront
10-20-2014 02:48 PM
ras4434
04-23-2006 05:09 PM
pockets
04-19-2006 03:41 PM
catmand9h
03-24-2002 05:18 AM
Quick Reply: 66 4x4 body shot, want new bed+body what year?
